v1.50
lamentin
v1.50
Post by lamentin »
hello,
have download 1.50
but with jdivelog no file hex to read ?
thanks
lamentin
Re: v1.50
Post by lamentin »
it's OK now
sorry
lamentin
Re: v1.50
Post by lamentin »
question : i've tried simulator with OC GF30/90 Tx 20/12 at 0m, Nx 36 at 30m, Nx 70 at 12m
first time i had second time i had
30m 1 same
24m 1 same
21m 2 same
18m 1 same
15m 3 15m 2
12m 3 12m 4
9m 6 9m 5
6m 10 same
3m 19 same
i've tried another 3 time => like first
why this difference ?
is it approximations ?
thanks
Re: v1.50
Which simulator did you use (Internal or PC-Based)? What was the bottom time?
lamentin
Re: v1.50
Post by lamentin »
it was internal simulator on OSTC : 21 min 60m
Olive
v1.50
Post by Olive »
hello,
have download 1.50
but with TinyBootloader no file hex to read ?
thanks
Re: v1.50
There are two downloads, the sourcecode without the HEX and the compiled HEX file. Download the attached archive (This is the compiled version).
gerstl_ossi
Re: v1.50
Post by gerstl_ossi »
I have a problem to download 1.50 Hex - File. Download stops at 101KB and all seams OK. When I try to open the Zip File I get a Error message.(tested with different PC's and operating systems.
Cheers Ossi
larry_berlin
Re: v1.50
Post by larry_berlin »
I have same problem like gerstl_ossi. Zip-file for hex code version 1.50 seems to be corrupt. Can't be unziped because of damaged file.
I tried Matthias's download from this forum also. Same problem.
Could you check please, Matthias!
Re: v1.50
Old issue, Microsoft Internet Explorer does not like the ZIP archives made with MS Windows XP... I have no idea why - happened since one of the last IE Updates.
Maybe the ZIP made by WINRAR (attached) will work?
PeterT
Re: v1.50
Post by PeterT »
doesn't work with IE either, with Firefox no problem!
Re: v1.50
Next try, a RAR file....
Cheers!
