Trouble to charge OSTC Plus battery
My OSTC Plus being locked, I had to remove and reinsert its battery ; this is the original 3.7 V rechargeable lithium battery.
When the computer starts (firmware 3.00 and later 3.01), I choose "3,6 V chargeable (T2)" - in fact 3.7 V. Then the computer indicates 99% but the voltage is only 3.0 V, meaning the battery is almost empty.
I put the computer on its inuctive charger, it is detected, charging starts and the green led ligths. But after a few seconds, the red led flashes and charging stops.
Any idea of what is wrong ?
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
Re: Trouble to charge OSTC Plus battery
Hi Didier,
Power supply sufficient? It should be at least 1.5A at 5V. In which circumstances did your unit freeze?
Thank for the advice : the charger was connected to a USB port of a laptop probably not able to provide enough current ; once connected to another power supply, charging looks ok.
This is strange because from the beginning (more than one year) I always used laptop USB port with no trouble ; maybe this time the battery was too deeply discharged ?
A last info : the unit was locked in dive mode (cf. our private exchanges last week).
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
An OSTC that is active, i.e. with screen (and hence backlight!) on, will draw more current from the charger compared to charging only while in sleep mode...
