Hello
after upgrading to 1.4.8, it is no longer possible to set date/time. Niether with OSTC Companion or directly on the unit. The unit also shows 0hPa and 0 Celsius.
Upgrade to 1.4.8 - no date/time
Kind regards,
Gorcio, OSTC MK2 828
Re: Upgrade to 1.4.8 - no date/time
Restore battery charge in Reset->Maintenance also does not work , even though it correctly remembers my unit to have been at 83% prior upgrade.
Kind regards,
Check this post(s): https://forum.heinrichsweikamp.com/read.php?7,21030 for details and the solution.
Thanks - that's solved the issue, except for Compass view.
Never mind - recalibrating compass helped.
Kind regards,
