How to use GF on MK2
Larscousteau
Post by Larscousteau »
Hello everbody..
I am now the lucky owner of the OSTC MK2 and have tryed to find out off how i can use the Gradient Factors/GF?
And can i use it while its in Buhlmann ZH-L16?
And i know it should me possibel to find out how to use the GF in the manuel but now i have read the manuel many times.
And look forward to hire from your
I will make a little movie with the OSTC MK2 in action and some pictures:-)
Larscousteau
Re: How to use GF on MK2
hmm.. so no answers:-) then there must be many with the same probem:-)
Steve
Post by Steve »
you should change your decomodel to ZH-L16 GF OC or CC
after you changed the decomodel you have to set your GF high and low.
Steve
CMAS 2* Instructor
Belgium
I'm not sure if i really understand your question.
You can set the OSTC either to ZH-L16 or L16-GF both in OC and CC.
When you choose ZH-L16 the setting of CF32 and CF33 ( GF ) has no effect.
If you want to bring the GF-settings ( CF 32 + 33 ) into effect you have to choose L16-GF.
In the mode ZH-L16 the GF used to be displayed but not used for deco calculation.
The standard GF-setting is CF32 = 30 and CF33 = 90.
To generate a deeper first stop you have to reduce CF32 to 20 or 10.
To generate a longer last stop ( 3 or 6 Mtr. ) you have to reduce CF33 to e.g. 80.
You can also go the more dangerous route for less deco-time and more micro-bubbles ( or even real bubbles ) with setting CF32 to more then 30 and CF33 to more then 90 but then the OSTC will warn you with a dead mans skull symbol.
If this doesn't help try to explain your question more detailed.
Reiner
Larscousteau
hello reiner..
and thank you for your answer..
i can se that i could have explain it better , but you came into my problem:-)
but still i dont understand when you write:
reduce cf32 to 20 or 10
is it in the custom functions2? and then i have to change the current to 20 or 10?
Steve
Post by Steve »
indeed it's in the custom functions but if you don't understand what GF-factors mean i suggest you learn more about it first before changing the factors.
Steve
CMAS 2* Instructor
Belgium
Larscousteau
Indeed i made this topic because thère is some thing i dont understand, and in my caise its how to set up the gradient factors.
I have never dived with a computer where its possibel to regulate the gradient, how Can i understand it if i cant control it/ ser it up.
So please keep to the topic and dont tell mé what or how i shall dive
ewatsch
Post by ewatsch »
Hello Larscosteau,
no need to be rude, we're just trying to help anyway.
If you want to change the gradient factors, use the custom functions (cf) 32 and 33 to a value you want.
In case you don't know what the gradient factors are influencing in your deco plan, you may read this article:
www.rebreatherworld.com/general-and-new ... mmies.html
All the best
Markus
Larscousteau
As i Can se i am not Rude and thar was not my plan to be it.
I made a topic because i cant find out of how to set the gradient factors?
And i am pleased with All the help i cant get and find the help from Sailor good and the link you just gave mé Ewatch.
PeterT
Post by PeterT »
There has already bin a topic on GF on this forum:
http://www.heinrichsweikamp.com/read.php?2,1819
fun readings and like Steve said, learn more about it before you start in-water experimenting!
grtz
Peter
Larscousteau
once again thanks for the help.
And i have no plan of using it before i know any thing about it.
and the only way to get the knowlegde about it is bye asking and reading. and ii wont to control the computer i have to know how to "install it"
grtz
Lars
