OSTC4 Pairing issue
Raff
OSTC4 Pairing issue
Post by Raff »
I am experiencing difficulties pairing a newly purchased OSTC4:-
Windows 10 PC (64-bit)
OSTC Companion v3 appears to have successfully installed
Bluetooth enabled on PC and in OSTC4 settings
OSTC4 lists as paired device ("OSTC4-00264")
However, when I attempt connection via OSTC Companion the following error message is generated:
"OSTC4 selected.
Connecting...
Port is not defined.
Port : Port is not defined.
Error: Port : Port is not defined."
It was my understanding from the manual that driver installation is not required. From Devices>Properties>Hardware I don't see a COM port defined so as to enter into OSTC Companion.
Would much appreciate some advice please. Thanks.
Re: OSTC4 Pairing issue
What port is set in the companion (Small gear Icon)?
Raff
Post by Raff »
COM port field is currently blank in Companion settings.
Mark
Then this error "Port not defined" makes sense ;)
Check in Windows 10 Bluetooth settings -> Advanced Bluetooth settings which com port has been assigned to the OSTC4 and just enter it in this field. Like "COM3".
Raff
Post by Raff »
Thanks for this further advice. I had not realised that the Port settings needed to be accessed via 'Further Bluetooth Options'. Added to which, another peripheral was interfering....
With a bit more trial and error, now have it working.
I still think my old OSTC 2n is great, but the OSTC4 is a fantastic dive computer.
Mark
