battery setting in the OSTC plus
yannick
Post by yannick »
Little problem with the new update 3.10 on my ostc2 Tech : update ok but battery at 99 % after , ( 55 % before ) and the charging pad Flashing RED ( charger 2A) .
What do you thing about ?
yannick #17955
jb2cool
Re: update 3.10
Post by jb2cool »
Does the par stay red or if you leave the computer on the pad does it ever recover to green? I believe if the computer needs a lot of charging the charging pad will occasionally turn red to give the battery a rest during charging, it should recover again and carry on the charging if you leave it.
Re: update 3.10
please check our FAQ article here: viewtopic.php?f=6&t=21023 and make sure the following is correct:
- T2 is selected in front of the battery voltage
If not, please go to Menu -> Settings -> System Settings -> Reset menu -> Reset battery and seelct T2 there.
yannick
Re: update 3.10
Post by yannick »
hello jb2cool
you're Wright . After a night, pad green and charge 0K . Thanks.
Yannick
