battery setting in the OSTC plus
Posted: 10 May 2020, 03:16
by yannick
Little problem with the new update 3.10 on my ostc2 Tech : update ok but battery at 99 % after , ( 55 % before ) and the charging pad Flashing RED ( charger 2A) .
What do you thing about ?
yannick #17955
Re: update 3.10
Posted: 10 May 2020, 08:44
by jb2cool
Does the par stay red or if you leave the computer on the pad does it ever recover to green? I believe if the computer needs a lot of charging the charging pad will occasionally turn red to give the battery a rest during charging, it should recover again and carry on the charging if you leave it.
Re: update 3.10
Posted: 10 May 2020, 11:12
please check our FAQ article here:
viewtopic.php?f=6&t=21023 and make sure the following is correct:
- T2 is selected in front of the battery voltage
If not, please go to Menu -> Settings -> System Settings -> Reset menu -> Reset battery and seelct T2 there.
Re: update 3.10
Posted: 10 May 2020, 21:29
by yannick
hello jb2cool
you're Wright . After a night, pad green and charge 0K . Thanks.
Yannick
