hwOS4: New Firmware 1.5.5 with RTE 2.05
Update 201001: 1.5.5 added
ENGLISH below.
Die neue Firmware 1.5.5 ist nun veröffentlicht.
heinrichsweikamp.com
Anleitung zur Installation: viewtopic.php?f=7&t=19186 (Je nach aktueller Version kann es nötig sein, das Update zweimal zu starten. Der OSTC4 gibt dazu nach dem Update nötigenfalls eine Meldung aus. Grund ist, dass möglicherweise auch sehr alte Teile der Firmware wie der Schriftsatz und der Bootloader aktualisiert werden.)
Wir emfehlen ein Update über die Apps OSTConf (iOS) oder HWOS Config (Android)
Videos:
OSTConf: https://www.facebook.com/17049381164554 ... 339989145/
HWOS Config: https://www.facebook.com/17049381164554 ... 561539708/
Folgende Änderungen und Neuerungen gibt es seit der V 1.5.1:
[1.5.5] with RTE 2.05
NEW: SYS3 menu where all custom views can be configured in detail (center, corner and big font)
FIX: Disable compass properly when not in use (end-2019 hardware only)
NEW: Added new option to gas configuration: "Off" (These are then not shown in the custom gas list)
FIX: Startup behaviour in cases where incorrectly stored dives are in the internal logbook
[1.5.4] with RTE 2.04
FIX: support for some old harwdare versions was broken in 1.5.3 (Only serial number <100 were affected)
CHG: layout in internal logbook cleaned
CHG: Only switch between "no fly" and "desaturation" in case there is desaturation time left
FIX: Balance value of button responsitivness were not considered during firmware startup
CHG: internal improvements in sleep mode
FIX: use dummy profile if necessary (If there are corrupted dives in the logbook)
[1.5.3] with RTE 2.03
CHG: Always show battery voltage in surface mode
CHG: battery status is now preserved for future updates
NEW: Support for much faster updates (With OSTC companion 3.2 and later)
FIX: (very) short screen lag removed during sample storage in dive mode
[1.5.2] with RTE 2.02
Beta Version!
FIX: display of time of minimum voltage
FIX: Display of Sensor values. At divestart sensor values were shown even sensors were deactivated (fix SP)
FIX: Bugfix invalid voltage / temperature after coldstart
FIX: Instant dive start at several meters out of sleep mode (Jumping into the water) may resulted in lagged/freeze depth reading
CHG: Speed increase of Bluetooth communications
CHG: Look and Feel for Gauge/Apnea mode with flipped screen improved
FIX: Deco warning after Gauge mode
FIX: Download issues of corrupted dives
FIX: Proper logbook write (Very spurious error, mainly in CCR mode)
[1.5.1] with RTE 2.01
NEW: Support for end-2019 hardware
The new firmware 1.5.5 is now public.
Manual on how to install: viewtopic.php?f=7&t=19186
(Depending on your current version it may be required to start the update twice. The OSTC4 will show you a message after the update if this is required. Reason is, that this update also may update some older parts of the firmware like the font table and the bootloader).
To update, simply use one of our two apps OSTConf for iOS or HWOS Config for Android.
The following changes have been made since V 1.5.1:
Beta Version!
Re: hwOS4: New Firmware 1.5.5 with RTE 2.05
