hwOS Sport: New Firmware 10.68
Posted: 29 Oct 2020, 09:51
The new hwOS sport firmware 10.68 is now available for download:
This update is (still) strongly recommended for all users of the 10.56 or later:
BUGFIX: Hardware versions 13-xx-xx and 58-xx-xx could hang up with versions of 10.56 or later
[10.68]
NEW: Support for current hardware version of OSTC 2 and plus
FIX: Abort on unknown parameter in comm mode
CHANGE: Several small language fixes
CHANGE: increase battery safety margins for Saft (T0) and 16650 batteries (T4)
[10.67]
BUGFIX: Surface pressure compensation (zero meter reference) could be delayed or stuck to old reference value
BUGFIX: configuring deco-gases via the mobile Apps was not possible
CHANGE: French language fixes
[10.66]
BUGFIX: Improved calculation accuracy of the initial ascent. Remark: this will have a slight impact on the resulting deco schedule compared to firmware 10.64.
CHANGE: The menu system around setting up the dive mode & settings has been decluttered. All settings are now sorted into the groups dive setup, deco setup, SAC (gas needs) setup, ppO2 setup and stops & depths setup. NEW: There is a new option "Swap on empty" in Dive setup -> SAC Setup. It is only effective if "CalcGas(B/O)" is switched on, too. If both options are switched on, the deco calculation will switch to another tank (i.e. gas) once the tank of the current gas is calculated to be used up. This function can be used to automatically calculate a contingency in case of running out of a deco gas, as the deco calculation will then continue to calculate a deco making use of the spares from the another gases carried. Another application is with two or more tanks holding the same gas (i.e. independent double configuration, side-mount), as the calculations will then take the cumulative amount of gas carried into account before raising a gas needs attention or alarm.
NEW: For dives done on firmware >= 10.66 the logbook will have one more page showing the tissue pressures and supersaturation levels as of at the end of dive (i.e. when surfacing).
NEW: New option to acknowledge the most recent warning in dive mode (Left press -> Ackn?)
BUGFIX: Hardened all USB/Bluetooth communication against data losses and timeouts
NEW: A new Firmware Recovery Feature has been added: the currently active firmware can be backed-up and restored later on while other firmwares have been loaded thereafter. The feature is accessible via Settings -> System Settings -> Reset Menu -> Reboot and becomes available with the first firmware load after the 10.66 (or later) is already on the unit.
BUGFIX: During loading of a new firmware the clock will not loose time any more (on old firmware it became late by about 15 sec on each firmware update).
CHANGE: When run from a 3.6 V battery (either replaceable or built-in), the surface mode timeout is now extended to 4 minutes before going to sleep mode. If the OSTC is run from 1.5 V disposables, the timeout remains at the previous 90 seconds to save on battery runtime.
NEW: Updates OSTC 2 TR computers to RX-Firmware 1.40
[10.64]
BUGFIX: "Sticky" button behaviour on some hardware versions (Only OSTC 2 (2017), TR and OSTC plus)
[10.63]
BUGFIX: Add surface part at end of dive to surface interval properly
BUGFIX: Average depth in logbook did not took salinity setting into account
CHANGE: Change color of temperature values in logbook to yellow
[10.60]
BUGFIX: Surfacemode could freeze in some hardware versions
BUGFIX: Potential issue with Bluetooth in older OSTC sport models
CHANGE: Default language in EN/DE version is English again
It contains RX firmware 1.40 for all OSTC 2 TR users.
How to install: viewtopic.php?f=6&t=14509&sid=523868e80 ... 5f630b93c2
Die neue hwOS sport Firmware 10.68 ist jetzt zum kostenlosen Download verfügbar:
Für alle Nutzer der 10.56 oder später ist dieses Update (immer noch) dringend empfohlen:
BUGFIX: Hardware versionen 13-xx-xx und 58-xx-xx konnten einfrieren für alle Versionen 10.56 oder später
[10.68]
NEU: Unterstützung für aktuelle Platinen-Version im OSTC2 und plus
BUGFIX: Abbruch bei unbekannten parametern während der Bluetooth-Konfiguration via App
ÄNDERUNG: Eine Begriffe im Menü wurden präzisiert
ÄNDERUNG: Für die LS14500 SAFT (T0) (Nur im OSTC sport) und für die 16650 (T4) im OSTC 2 wurde die Sicherheitsmarge bei der Kapazitätsberechnung erhöht
[10.67]
BUGFIX: Oberflächendruck-Kompensation (Null Meter Referenz) konnte verzögert oder auf dem alten Wert stehen bleiben
BUGFIX: Parametrisieren von Dekogasen über die Smartphone Apps war nicht möglich
CHANGE: Updates bei der Französischen Sprachversion
[10.66]
BUGFIX: Verbesserte Berechnungsgenauigkeit des Erstaufstiegs. Bemerkung: dies wird einen leichten Einfluss auf den resultierenden Dekoplan haben, verglichen mit der 10.64
ÄNDERUNG: Das Menüsystem zum Einrichten des Tauchmodus und der Einstellungen wurde aufgeräumt. Alle Einstellungen sind jetzt in die Gruppen TG-Einstellungen sortiert, Dekompression, SAC (Gasbedarf)-Einstellung, O2 Partialdruck und Stopps und Tiefen.
NEU: Es gibt eine neue Option "Swap on empty" in TG-Einstellungen -> SAC Einstellung. Sie ist nur wirksam, wenn auch "CalcGas(B/O)" eingeschaltet ist. Wenn beide Optionen eingeschaltet sind, wechselt die Deko-Berechnung zu einem anderen, aktiven Tank (d.h. Gas), sobald der Tank des aktuellen Gases in der Berechnung verbraucht ist. Dies ist vor allem für Sidemount-Taucher interessant da hierbei der Gasvorrat beider Flaschen gleichzeitig berücksichtig wird.
NEU: Für TG mit Firmware >= 10.66 wird im Logbuch noch eine weitere Detailseite mit Sättigunsdaten angezeigt
NEU: Warnungen können im Tauchmodus bestätigt und damit weggeschaltet werden (Linke Taste -> Best?)
BUGFIX: Die gesamte USB/Bluetooth-Kommunikation wurde gegen Datenverluste und Timeouts abgehärtet
NEU: Eine neue Firmware-Wiederherstellungsfunktion wurde hinzugefügt: die derzeit aktive Firmware kann gesichert und später wiederhergestellt werden, während andere Firmwares geladen wurden. Die Funktion ist zugänglich über Konfiguration -> System -> Reset Menü -> Neustart/Backup und wird mit dem ersten Laden einer Firmware verfügbar nach der 10.66 (oder später).
BUGFIX: Beim Laden einer neuen Firmware verliert die Uhr keine Zeit mehr (bei der alten Firmware kam es bei jedem Firmware-Update zu einer Verspätung von etwa 15 Sekunden).
CHANGE: Bei Betrieb mit einer 3,6-V-Batterie (entweder austauschbar oder eingebaut) wird der Timeout auf 4 Minuten vor dem Einschlafen verlängert. Bei 1,5V Batterien bleibt es bei 90 um die Batterie zu schonen
NEU: Aktualisiert OSTC 2 TR-Computer auf RX-Firmware 1.40
[10.64]
BUGFIX: In bestimmten Hardwareversionen konnten die Taster "hängen" (Nur OSTC 2 (2017), TR und OSTC plus)
[10.63]
BUGFIX: Der flache Bereich am TG-Ende wurde nicht zum Oberflächenintervall addiert
BUGFIX: Die Durschnittstiefe im Logbuch wurde ohne den eingestellten Salzgehalt angezeigt
CHANGE: Temperaturwerte im Logbuch werden jetzt in gelb angezeigt.
[10.60]
BUGFIX: Oberflächemodus konnte bei bestimmten Hardwareversionen einfrieren
BUGFIX: Mögliches Bluetooth Problem beim alten OSTC sport (rote Taster)
CHANGE: Standard-Sprache in der EN/DE Version ist jetzt wieder Englisch
[10.58]
BUGFIX: Versionsnummer wurde im Oberflächenbildschirm nicht angezeigt
BUGFIX: Taster konnte auf dem Lader "durchrollen"
Es enthält die RX firmware 1.40 für alle OSTC 2 TR Benutzer.
Bitte Fragen zum Update/Probleme beim Update in einem neuen Thread posten.
[10.68]
[10.67]
[10.66]
[10.64]
[10.63]
[10.60]
[10.68]
[10.67]
[10.66]
[10.64]
[10.63]
[10.60]
[10.58]
