hwOS Sport: New Firmware 10.70
Posted: 24 May 2021, 17:28
The new hwOS sport firmware 10.70 is now available for download:
This update is (still) strongly recommended for all users of the 10.56 or later:
BUGFIX: Hardware versions 13-xx-xx and 58-xx-xx could hang up with versions of 10.56 or later
[10.70]
NEW: Support for new pressure sensor type in OSTC 2 and plus
NEW: Several changes in the different language versions
CHANGE: Tweak gas use routine to work with unplanned changes (Switching to inactive gases)
BUGFIX: Pulsing of backlight under some conditions fixed
NEW: Large (Single line) menu in dive mode when large layout is selected
[10.68]
NEW: Support for current hardware version of OSTC 2 and plus
FIX: Abort on unknown parameter in comm mode
CHANGE: Several small language fixes
CHANGE: increase battery safety margins for Saft (T0) and 16650 batteries (T4)
[10.67]
BUGFIX: configuring deco-gases via the mobile Apps was not possible
CHANGE: French language fixes
[10.66]
BUGFIX: Improved calculation accuracy of the initial ascent. Remark: this will have a slight impact on the resulting deco schedule compared to firmware 10.64.
CHANGE: The menu system around setting up the dive mode & settings has been decluttered. All settings are now sorted into the groups dive setup, deco setup, SAC (gas needs) setup, ppO2 setup and stops & depths setup. NEW: There is a new option "Swap on empty" in Dive setup -> SAC Setup. It is only effective if "CalcGas(B/O)" is switched on, too. If both options are switched on, the deco calculation will switch to another tank (i.e. gas) once the tank of the current gas is calculated to be used up. This function can be used to automatically calculate a contingency in case of running out of a deco gas, as the deco calculation will then continue to calculate a deco making use of the spares from the another gases carried. Another application is with two or more tanks holding the same gas (i.e. independent double configuration, side-mount), as the calculations will then take the cumulative amount of gas carried into account before raising a gas needs attention or alarm.
NEW: For dives done on firmware >= 10.66 the logbook will have one more page showing the tissue pressures and supersaturation levels as of at the end of dive (i.e. when surfacing).
NEW: New option to acknowledge the most recent warning in dive mode (Left press -> Ackn?)
BUGFIX: Hardened all USB/Bluetooth communication against data losses and timeouts
NEW: A new Firmware Recovery Feature has been added: the currently active firmware can be backed-up and restored later on while other firmwares have been loaded thereafter. The feature is accessible via Settings -> System Settings -> Reset Menu -> Reboot and becomes available with the first firmware load after the 10.66 (or later) is already on the unit.
BUGFIX: During loading of a new firmware the clock will not loose time any more (on old firmware it became late by about 15 sec on each firmware update).
CHANGE: When run from a 3.6 V battery (either replaceable or built-in), the surface mode timeout is now extended to 4 minutes before going to sleep mode. If the OSTC is run from 1.5 V disposables, the timeout remains at the previous 90 seconds to save on battery runtime.
NEW: Updates OSTC 2 TR computers to RX-Firmware 1.40
[10.64]
BUGFIX: "Sticky" button behaviour on some hardware versions (Only OSTC 2 (2017), TR and OSTC plus)
[10.63]
BUGFIX: Add surface part at end of dive to surface interval properly
BUGFIX: Average depth in logbook did not took salinity setting into account
CHANGE: Change color of temperature values in logbook to yellow
It contains RX firmware 1.41 for all OSTC 2 TR users.
How to install: https://forum.heinrichsweikamp.com/view ... 5f630b93c2
Die neue hwOS sport Firmware 10.70 ist jetzt zum kostenlosen Download verfügbar:
Für alle Nutzer der 10.56 oder später ist dieses Update (immer noch) dringend empfohlen:
BUGFIX: Hardware versionen 13-xx-xx und 58-xx-xx konnten einfrieren für alle Versionen 10.56 oder später
Die folgenden Änderungen wurden gemacht:
[10.70]
NEU: Unterstützung für neuen Drucksensor in OSTC 2 und plus
NEU: Sprachupdates
ÄNDERUNG: Verhalten beim Wechsel auf inaktive Gase
BUGFIX: Hintergrundbeleuchtung konnte unter bestimmten Bedingungen pulsieren
NEU: In der Großansicht wird das Tauchmodus-Menü in großer Schrift (Eine Zeile) dargestellt
[10.68]
NEU: Unterstützung für aktuelle Platinen-Version im OSTC2 und plus
BUGFIX: Abbruch bei unbekannten parametern während der Bluetooth-Konfiguration via App
ÄNDERUNG: Eine Begriffe im Menü wurden präzisiert
ÄNDERUNG: Für die LS14500 SAFT (T0) (Nur im OSTC sport) und für die 16650 (T4) im OSTC 2 wurde die Sicherheitsmarge bei der Kapazitätsberechnung erhöht
[10.67]
CHANGE: Updates bei der Französischen Sprachversion
[10.66]
BUGFIX: Verbesserte Berechnungsgenauigkeit des Erstaufstiegs. Bemerkung: dies wird einen leichten Einfluss auf den resultierenden Dekoplan haben, verglichen mit der 10.64
ÄNDERUNG: Das Menüsystem zum Einrichten des Tauchmodus und der Einstellungen wurde aufgeräumt. Alle Einstellungen sind jetzt in die Gruppen TG-Einstellungen sortiert, Dekompression, SAC (Gasbedarf)-Einstellung, O2 Partialdruck und Stopps und Tiefen.
NEU: Für TG mit Firmware >= 10.66 wird im Logbuch noch eine weitere Detailseite mit Sättigunsdaten angezeigt
NEU: Eine neue Firmware-Wiederherstellungsfunktion wurde hinzugefügt: die derzeit aktive Firmware kann gesichert und später wiederhergestellt werden, während andere Firmwares geladen wurden. Die Funktion ist zugänglich über Konfiguration -> System -> Reset Menü -> Neustart/Backup und wird mit dem ersten Laden einer Firmware verfügbar nach der 10.66 (oder später).
CHANGE: Bei Betrieb mit einer 3,6-V-Batterie (entweder austauschbar oder eingebaut) wird der Timeout auf 4 Minuten vor dem Einschlafen verlängert. Bei 1,5V Batterien bleibt es bei 90 um die Batterie zu schonen
NEU: Aktualisiert OSTC 2 TR-Computer auf RX-Firmware 1.40
[10.64]
[10.63]
BUGFIX: Der flache Bereich am TG-Ende wurde nicht zum Oberflächenintervall addiert
BUGFIX: Die Durschnittstiefe im Logbuch wurde ohne den eingestellten Salzgehalt angezeigt
CHANGE: Temperaturwerte im Logbuch werden jetzt in gelb angezeigt.
Es enthält die RX firmware 1.41 für alle OSTC 2 TR Benutzer.
Bitte Fragen zum Update/Probleme beim Update in einem neuen Thread posten.
Re: hwOS Sport: New Firmware 10.70
Posted: 26 May 2021, 13:49
by kugelfisch01
ich habe gerade versucht die Firmware zu aktualisieren von 10.68 auf 10.70 (OSTC Sport). Bei mir funktioniert das Update nicht. Es läuft alles durch, der TC startet neu und danach ist immer noch die Firmware 10.68 drauf. Fehlermeldungen gibt es nicht.
Habe es von einem Samsung Galaxy S20+ mit dem App von Robert versucht
und über ein Iphone 12 Mini via OSTC Conf.
Auch die Tec-Software macht mit einem OSTC-Sport das gleiche Problem.
Hoffe es passt hier rein.
Posted: 26 May 2021, 14:29
by moreno
Hi!
Same result!
I have tried with HWOS Config and Subsurface.
OSTC Sport 21575
Posted: 26 May 2021, 15:25
by Stardrowned
auf meinem OSTC Sport ging es ohne Probleme, habe das Update mit OSTC Companion v3.2.1 durchgeführt.
Posted: 26 May 2021, 16:04
kugelfisch01 wrote: 26 May 2021, 13:49 Auch die Tec-Software macht mit einem OSTC-Sport das gleiche Problem.
In so einem Fall bitte per "OSTC sport Helper" mal versuchen:
Lade den Sport Helper: https://www.heinrichsweikamp.net/downlo ... helper.zip
1. Reset Menu -> Reboot, drücke (und halte) den rechten Taster bis das Bluetooth Icon erscheint
2. "Paare" den OSTC Sport mit einem Windows PC (Das ist vermutlich bereits geschehen)
3. Starte den "ostc helper"
- Entpacke alle Dateien in ein Verzeichnis
- Starte tinybld.exe
- Wähle den richtigen Bluetooth Com port aus
- Drücke update firmware
- Warte bis das gelbe Warndreieck aus ist
Danach kann die Firmware mit der companion software neu bespielt werden (Sofern noch nötig). Das geht auch bei einem TECH OSTC. Danach die normale TECH Version per App wieder aufspielen. Es gehen dabei keine Daten (Tauchgänge) verloren.
Ich hoffe das hilft...
Download the OSTC Sport Helper: https://www.heinrichsweikamp.net/downlo ... helper.zip
1. Press right button (After inserting the battery and closing the battery cap) -> The bluetooth icon should appear
2. Pair unit with a Windows PC (Most likely, this is done already)
3. use "ostc helper"
- unzip all files (!)
- start tinybld.exe
- choose correct bluetooth com port
- press update firmware
- wait until the yellow warning sign is off
After this, you can reinstall everything with the companion software or with the mobile Apps (If required).
Hope this helps...
Posted: 27 May 2021, 11:25
by moreno
Thanks.
Posted: 27 May 2021, 19:49
by Sp3xX
Had the same problem at first - but your tips did help!
First time ever that happened
Posted: 30 May 2021, 14:58
by redwoody
juste updated my OSTC 2 with new firmware.
Everything worked fine with OSTConf on apple iOS
I see there is compatibility with pressure sensors as new features. Do you mean tank pressure sensors or internal ambiant pressure? If tank, what are the model(s) available ?
Thanks a lot.
Posted: 30 May 2021, 20:30
by moreno
Hi!
After update with 10.70 i had 2 dives.
The diving computer works fine but I cannot any more transfer my dives to Subsurface.
I try to transfer with Subsurface on mobile phone, Linux and Windows without results just the message:
I try to transfer on DivingLog 6.0 with same result.
I managed to download libdivecomputer logfile and dumpfile (I can send the link to download).
Please help.
Posted: 01 Jun 2021, 15:31
by moreno
Hi!
After a complete dive log reset everything works fine.
Posted: 02 Jun 2021, 10:16
moreno wrote: 01 Jun 2021, 15:31 Hi!
Thanks for the feedback. Here I really don't expect any issue in the OSTC firmware. There were no changes reagrding this and we did not see this behaviour on our own units.
Posted: 02 Jun 2021, 13:09
by moreno
Maybe was some problem with diving log file.
The file I downloaded from my computer have about 100 dive logs inside and 8MB.
It's possible to open it with another application and retrive the dives?
Posted: 03 Jun 2021, 07:55
Yes, Subsurface.
Posted: 10 Jun 2021, 20:12
by finger
hallo zusammen
gibt es den "HELPER" auch für macOS ?
ich bringe die version vom 10.68 auch nicht auf den 10.70er
danke und gruss vom thunersee
urs
#21211
Posted: 14 Jun 2021, 16:11
finger wrote: 10 Jun 2021, 20:12 gibt es den "HELPER" auch für macOS ?
Leider nein. Mann muss allerdings sagen, das zwischen der 10.68 und der 10.70 nicht so richtig viel Neu ist. Die 10.70 ist primär gekommen, um neue Hardware-Versionen zu unterstützen. Vielleicht hilft Dir in dem Fall mal jemand mit einem Windows-PC aus oder melde Dich mal bei uns. Wir sind zum tauchen immer wieder mal selbst am Thunersee, da könnte man sich mal kurz treffen.
Posted: 16 Jun 2021, 09:55
by Julian_dm
Hey hat funktioniert :D nach dem sport Helper hat sich die software selbst zu 10.70 aktualisiert. Hab nur leider aus Versehen alle DiveLogs gelöscht :cry: Ganze 20 ;)
Posted: 19 Jun 2021, 19:14
by poaskay
Hello, the new update 10.70 reads: "NEW: Large menu (one line) in dive mode when large layout is selected ..", someone dived with this update, see better took a picture of the screen during the dive with this new screen? thank you
Posted: 19 Jun 2021, 19:58
by Ralph
Try out yourself! Install the update, start the dive simulator and switch to the large font layout...
Posted: 02 Jul 2021, 15:54
by R4cOOn
Like one of the poster earlier I also cannot update my OSTC Sport from 1.68 to 1.70 using the Android App.
My phone shows up as having the "Tech" firmware but with the "Sport" version 1.68 in the App (which doesn't make any sense, I don't have the "Tech" version).
When I trigger the update it looks like it's doing its thing.
The OSTC then reboots but still shows version 1.68
Will using the tinybldWin.exe in the procedure described above going to reset my dive statistics?
Cheers.
Posted: 23 Jul 2021, 15:08
by mnk
Everything mentiones here I tryed without succsess. My Sport remains on 10.68
Sport_helper tells me that I have a wrong port, thats the reason why I could not try these way. All others are working but after all there still is 10.68 remaining.
Looking for help, thanks.
Posted: 24 Jul 2021, 14:15
by Alubuddel
heinrichsweikamp wrote: 26 May 2021, 16:04
Moin, bei mir dasselbe Problem mit dem FW-Update :-(
(Sorry, falscher Thread da Update auf 3.15 Tech, aber gleiches Problem)
Wenn ich den OSTC Sport neu boote und dabei den rechten Taster dabei gedrückt halte startet der OSTC neu, es kommt aber kein BT-Logo.
Updateversuche über Android, Subsurface und Companion alle vergeblich. Warum ist das bei euch nur so kompliziert :shock:
EDIT meinte, ich soll die Display-Drehung mal rausnehmen und dann den "rechten Taster" drücken. Jetzt wird zumindest beim Reboot das BT-Logo eingeblendet. Dafür findet der Tiny Bootloader den OSTC auf Com4 nicht (auf Com3 natürlich auch nicht) :-(
Posted: 25 Jul 2021, 06:09
by gr3yw0lf
und was passiert, wenn du im tiny bootloader das häckchen bei "COM port search" setzt? siehst du dann auch andere com ports? kann manchmal mühsam sein, wenn du statt "COM 4" "com 4" hast....
Posted: 25 Jul 2021, 12:08
by Alubuddel
Hab ich alles durchprobiert. Nachdem die Verbindung nach der Anleitung von Matthias nicht gefunzt hat, habe ich alle anderen Optionen ausprobiert. Ohne Erfolg :-(
EDIT: - Nachtrag
Nachdem ich mit den gleichen Einstellungen und dem gleichen Procedere das Aufspielen mittels des Tiny Bootloader zum dritten mal probiert habe ging das Update auf die 10.xx Firmware. Auch die Com-Ports wurden jetzt alle in Großschrift dargestellt (gestern teils in Kleinschrift). Update auf die 3.15 Tech mittles Subsurface ging dann auch glatt durch, ebenso fand der Companion den OSTC wieder korrekt.
Ja, ich weiß, OSCT-Hardware -> BT-Modul -> BT-Empfänger -> Betriebssystem -> Software und die ganze Strecker wieder zurück zum OSTC ist schon ein bisschen herausfordernd, jedoch verstehe ich nicht, dass es immer noch zu solchen Komplikationen kommt.
Posted: 11 Sep 2021, 20:18
by Bubba71394
Problem beim OSTC Sport mit Tec update...: Was tue ich denn, wenn ich kein Windows-Laptop zur Hand habe. Gibt es immer noch keine Möglichkeit über iOS (MBP oder iPhoneX)? Kaufst Dir den tec update und bekommst kein Firmware hin ... irgendwie fast ne Ironie-Nummer ;)
Posted: 15 Oct 2021, 11:52
