Logbook broken
Java di Lungoni
Logbook broken
During a firmware upgrade my OSTC Sport crashed and I removed the battery. With a new battery I was able to upgrade the firmware to the 10.71 version but now the logbook is broken: if I try to enter in "logbook" menu the system return to the main menu.
Can someone help me?
Alberto
Alberto
Re: Logbook broken
I think the logbook is lost and to make sure it's properly setup for the next real dive I recommend a "Delete Logbook" from the Reset Menu in this case.
Java di Lungoni
Re: Logbook broken
Thank you for the reply.
I deleted the logbook and it started working again, but I lost my old dives.
After the last dive I can see the logbook but it is impossible to download the dive with Subsurface.
The bluetooth connection works: I was able to update the time with "HWOS Config".
I think the registry is partially broken - is there any way to fix it?
Thanks again
Alberto
Thanks again
Alberto
Re: Logbook broken
please post (or email) us the logfile (Check "Save libdivecopmputer logfile") that can be generated in Subsurface while downloading the dives. That will have some important information that might help us to help you.
Downloading on MAC OS 12.2.1? See: https://subsurface.github.io/faq/#i-can ... --monterey
Java di Lungoni
Re: Logbook broken
I used Subsurface 5.0.6 with Windows.
Thank you
Alberto
Thank you
Alberto
Re: Logbook broken
Please email us (or post here) the download "logfile", that contains technical information about the download process. You can generate it in Subsurface by checking the "Save libdivecopmputer logfile" box in the download window.
Java di Lungoni
Re: Logbook broken
in the last post I tried to attach the file but I was obviously wrong.
Now I copied the contents if the log file:
Subsurface: v5.0.6, built with libdivecomputer v0.8.0-devel-Subsurface-NG (17bc0faa5157517d90edc0e6353b3d4848324700)
[0.000000] INFO: Open: name=COM4
[3.622282] INFO: Configure: baudrate=115200, databits=8, parity=0, stopbits=0, flowcontrol=0
[3.622428] INFO: Timeout: value=3000
[3.622456] INFO: Sleep: value=300
[3.927656] INFO: Purge: direction=3
[3.928129] INFO: Write: size=1, data=BB
[3.954327] INFO: Read: size=1, data=BB
[3.997826] INFO: Read: size=1, data=4D
[3.998083] INFO: Write: size=1, data=60
[4.010907] INFO: Read: size=1, data=60
[4.010950] INFO: Read: size=5, data=0012000000
[4.010967] INFO: Read: size=1, data=4D
[4.011226] INFO: Write: size=1, data=69
[4.031018] INFO: Read: size=1, data=69
[4.031054] INFO: Read: size=64, data=0A540A48000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
[4.031071] INFO: Read: size=1, data=4D
Event: model=18 (0x00000012), firmware=2632 (0x00000a48), serial=21514 (0x0000540a)
[4.034156] INFO: Write: size=1, data=6D
[4.051772] INFO: Read: size=1, data=6D
[4.325219] INFO: Read: size=1024, data=3F0D00150B0E09109F0610002D010024070F00150B0E0932C80613002C020024961400150B1C0921F70A1C0037030024FC1600150A0E0C1F4C0D20003204002462170016011E0A04700F21001A050024E51A0016021A0F28180D270015060024571800160306091048112300000700247D160016030C0A35B50F200000080024FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
[4.509321] INFO: Read: size=1024, data=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
[4.723958] INFO: Read: size=1024, data=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
[4.964304] INFO: Read: size=1024, data=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
[4.964609] INFO: Read: size=1, data=4D
[4.964664] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964671] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964677] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964682] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964687] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964692] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964697] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964702] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964707] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964712] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964717] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964721] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964726] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964731] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964736] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964741] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964746] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964750] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964755] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964760] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964765] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964769] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964774] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964779] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964785] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964791] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964797] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964803] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964877] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964884] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964891] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964898] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964905] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964911] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964918] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964924] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964928] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964933] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964938] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964943] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964948] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964953] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964957] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964962] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964967] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964972] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964978] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964982] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964987] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964992] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.964997] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965003] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965008] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965014] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965019] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965026] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965031] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965036] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965042] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965047] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965052] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965058] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965063] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965069] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965073] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965079] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965084] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965089] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965094] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965264] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965269] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965274] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965279] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965284] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965288] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965293] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965298] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965303] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965307] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965312] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965317] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965322] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965327] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965331] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965336] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965341] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965346] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965351] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965355] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965360] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965365] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965370] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965375] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965380] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965384] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965389] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965394] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965399] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965404] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965408] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965413] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965418] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965423] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965428] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965432] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965437] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965442] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965447] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965452] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965457] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965505] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965510] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965514] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965519] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965524] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965529] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965534] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965539] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965543] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965548] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965553] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965558] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965563] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965567] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965572] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965577] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965582] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965587] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965591] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965596] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965601] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965606] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965611] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965615] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965620] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965625] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965630] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965635] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965639] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965644] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965649] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965654] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965658] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965663] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965668] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965673] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965678] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965682] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965687] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965692] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965728] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965733] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965738] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965743] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965747] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965752] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965757] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965762] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965767] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965771] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965776] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965781] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965786] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965790] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965795] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965800] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965805] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965809] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965814] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965819] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965824] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965829] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965834] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965838] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965843] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965848] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965853] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965858] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965863] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965867] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965872] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965877] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965882] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965887] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965892] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965897] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965901] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965906] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965911] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965916] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965921] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965956] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965961] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965965] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965970] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965975] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965980] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965985] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965989] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965994] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.965999] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966004] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966008] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966013] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966018] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966023] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966028] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966032] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966037] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966042] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966047] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966051] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966056] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966061] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966066] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966070] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966075] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966080] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966085] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966090] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966094] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966099] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966104] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966109] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966114] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966118] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966123] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966128] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966133] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966138] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966143] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966253] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966258] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966263] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966267] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966272] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966277] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966282] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966287] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966292] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966296] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966301] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966306] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966311] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966316] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966320] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966325] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966330] WARNING: Unexpected empty header found. [in src/hw_ostc3.c:746 (hw_ostc3_device_foreach)]
[4.966602] INFO: Write: size=1, data=66
[4.984000] INFO: Read: size=1, data=66
[4.984329] INFO: Write: size=1, data=07
[5.204593] INFO: Read: size=1024, data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
[5.238334] INFO: Read: size=1024, data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
[5.360900] INFO: Read: size=1024, data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
[5.497020] INFO: Read: size=1024, data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
[5.565465] INFO: Read: size=1024, data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
[5.596061] INFO: Read: size=890, data=005601005101005301005801004D0104500000F04E01004D01004A01003E01002A01002A0116500000F03000000000000000000000000000000005001D01000B0100EA0000D70000D40000B90004510000F0AE00008A00007E00006600005F0000330016510000F04600000000000000000000000000000005001300003100001B0000080000080000080004510000F0130000000000010000000000040000080016520000F04D00000000000000000000000000000005001F0000060000070000010000000000030004520000F00400000500000800001800001400000E0016520000F04A00000000000000000000000000000005000F0000110000110000110000150000130004520000F0140000170000140000140000020000020016520000F04A00000000000000000000000000000005000A00001300001B0000020000040000110004520000F01800001C00000B00000900000B00000E0016520000F04700000000000000000000000000000005000200000200000400000200000C0000200004520000F03800001D00001600000E0000150000310016520000F04200000000000000000000000000000005002C00002400001300000800001200000F0004520000F0140000120000180000180000100000140016520000F04300000000000000000000000000000005001400001500000F00000A00000C00000E0004520000F00E00000E00000700000D00000A00000D0016520000F04200000000000000000000000000000005000A00000B00000E0000030000060000050004520000F00300000F0000150000080000030000000016520000F0430000000000000000000000000000000500000000010000020000010000000000010004520000F0010000000000040000010000020000010016520000F0420000000000000000000000000000000500020000010000020000020000020000020004520000F0020000020000020000000000020000020016520000F0410000000000000000000000000000000500020000010000020000020000020000030004520000F0010000020000020000020000020000010016530000F0400000000000000000000000000000000500010000020000030000010000020000030004530000F0010000020000030000010000010000000016530000F03F0000000000000000000000000000000500020000030000020000020000010000010004530000F0FDFD
[5.596122] INFO: Read: size=1, data=4D
[5.598794] INFO: Write: size=1, data=66
[5.615300] INFO: Read: size=1, data=66
[5.615550] INFO: Write: size=1, data=06
[5.854737] INFO: Read: size=1024, data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
[8.855713] INFO: Read: size=579, data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
[8.855846] ERROR: Failed to receive the answer. [in src/hw_ostc3.c:333 (hw_ostc3_transfer)]
[8.855855] ERROR: Failed to read the dive. [in src/hw_ostc3.c:812 (hw_ostc3_device_foreach)]
[8.936727] INFO: Write: size=1, data=FF
[11.936203] INFO: Read: size=0, data=
[11.936214] ERROR: Failed to receive the echo. [in src/hw_ostc3.c:305 (hw_ostc3_transfer)]
[11.936221] ERROR: Failed to send the command. [in src/hw_ostc3.c:579 (hw_ostc3_device_close)]
Thank you
Alberto
Thank you
Alberto
Re: Logbook broken
There are some header files in your logbook memory that are invalid. You need to reset the logbook from the reset menu in this case, sorry. The unit will reformat the logbook memory then and new dives will be stored properly.
Java di Lungoni
Re: Logbook broken
Is not possible fix the logbook using dctools (libdivecomputer)?
It's the third time that I had problem during the synchronization between the OSTC Sport and Subsurface and I had the logbook broken. I often had problem with the Bluetooth connection also with HWOS Config (the OSTC freezes), even when I try to correct he clock. Maybe is it an hardware problem?
Thank you
Alberto
Thank you
Alberto
