hwOS Sport: New Firmware 10.75
The new hwOS sport firmware 10.75 is now available for download:
[10.75]
interrupted.
[10.74]
CHANGE: OSTC with mechanical (magnetic) buttons need both buttons being pressed to wake up
CHANGE: minor changes in the different language versions
BUGFIX: Bluetooth Reset option for 2022 OSTC sport models fixed
[10.73]
[10.72]
[10.71]
[10.70]
[10.68]
[10.67]
CHANGE: French language fixes
[10.66]
[10.64]
[10.63]
How to install: viewtopic.php?f=6&t=14509&sid=523868e80 ... 5f630b93c2
Die neue hwOS sport Firmware 10.75 ist jetzt zum kostenlosen Download verfügbar:
[10.75]
unterbrochen werden.
[10.73]
[10.72]
[10.71]
[10.70]
NEU: Sprachupdates
[10.68]
[10.67]
[10.66]
[10.64]
[10.63]
Re: hwOS Sport: New Firmware 10.75
Continue here: viewtopic.php?t=22420
