hwOS Sport: New Firmware 10.75
Posted: 28 Aug 2022, 11:44
The new hwOS sport firmware 10.75 is now available for download:
[10.75]
BUGFIX: Increase resolution of tissue pressure calculations to track very low pressure differences between ambient and tissue pressures
CHANGE: Support for new OSTC+ hardware with O2 sensor inputs
CHANGE: Adjust max. brightness settings
CHANGE: reset planning parameters to default values - only when entering the menu,
thus keeping the settings between multiple calculator runs
FIX: the output of the calculation results was divided into several steps, which
could be interrupted in cooperative multitasking. So glitches could occur in the
screen output if e.g. the TTS switched to NDL but the deco data flag vector was
not updated yet. Now the compilation of all calculation results can no longer be
interrupted.
[10.74]
CHANGE: OSTC with mechanical (magnetic) buttons need both buttons being pressed to wake up
CHANGE: minor changes in the different language versions
BUGFIX: Bluetooth Reset option for 2022 OSTC sport models fixed
CHANGE: Compatibility for new hardware versions
[10.73]
[10.72]
NEW: Support for current hardware version of OSTC 2, plus and Sport
- a Reset Bluetooth from the Reset Menu might be required for BLE/Bluetooth 4.0 to be enabled
[10.71]
BUGFIX: Sensor detection in OSTC plus could fail for some hardware versions
BUGFIX: calculate time/date of the end of the dive in logbook screen correctly for
dives with a lot of surface time/many descents
NEW: Different brightness settings for dive and surface mode
NEW: minor changes in the different language versions
BUGFIX: Reduce sleep mode current
[10.70]
NEW: Support for new pressure sensor type in OSTC 2 and plus
NEW: Several changes in the different language versions
CHANGE: Tweak gas use routine to work with unplanned changes (Switching to inactive gases)
BUGFIX: Pulsing of backlight under some conditions fixed
NEW: Large (Single line) menu in dive mode when large layout is selected
[10.68]
NEW: Support for current hardware version of OSTC 2 and plus
FIX: Abort on unknown parameter in comm mode
CHANGE: Several small language fixes
CHANGE: increase battery safety margins for Saft (T0) and 16650 batteries (T4)
[10.67]
BUGFIX: configuring deco-gases via the mobile Apps was not possible
CHANGE: French language fixes
[10.66]
BUGFIX: Improved calculation accuracy of the initial ascent. Remark: this will have a slight impact on the resulting deco schedule compared to firmware 10.64.
CHANGE: The menu system around setting up the dive mode & settings has been decluttered. All settings are now sorted into the groups dive setup, deco setup, SAC (gas needs) setup, ppO2 setup and stops & depths setup. NEW: There is a new option "Swap on empty" in Dive setup -> SAC Setup. It is only effective if "CalcGas(B/O)" is switched on, too. If both options are switched on, the deco calculation will switch to another tank (i.e. gas) once the tank of the current gas is calculated to be used up. This function can be used to automatically calculate a contingency in case of running out of a deco gas, as the deco calculation will then continue to calculate a deco making use of the spares from the another gases carried. Another application is with two or more tanks holding the same gas (i.e. independent double configuration, side-mount), as the calculations will then take the cumulative amount of gas carried into account before raising a gas needs attention or alarm.
NEW: For dives done on firmware >= 10.66 the logbook will have one more page showing the tissue pressures and supersaturation levels as of at the end of dive (i.e. when surfacing).
NEW: New option to acknowledge the most recent warning in dive mode (Left press -> Ackn?)
BUGFIX: Hardened all USB/Bluetooth communication against data losses and timeouts
NEW: A new Firmware Recovery Feature has been added: the currently active firmware can be backed-up and restored later on while other firmwares have been loaded thereafter. The feature is accessible via Settings -> System Settings -> Reset Menu -> Reboot and becomes available with the first firmware load after the 10.66 (or later) is already on the unit.
BUGFIX: During loading of a new firmware the clock will not loose time any more (on old firmware it became late by about 15 sec on each firmware update).
CHANGE: When run from a 3.6 V battery (either replaceable or built-in), the surface mode timeout is now extended to 4 minutes before going to sleep mode. If the OSTC is run from 1.5 V disposables, the timeout remains at the previous 90 seconds to save on battery runtime.
NEW: Updates OSTC 2 TR computers to RX-Firmware 1.40
[10.64]
BUGFIX: "Sticky" button behaviour on some hardware versions (Only OSTC 2 (2017), TR and OSTC plus)
[10.63]
BUGFIX: Add surface part at end of dive to surface interval properly
BUGFIX: Average depth in logbook did not took salinity setting into account
CHANGE: Change color of temperature values in logbook to yellow
It contains RX firmware 1.41 for all OSTC 2 TR users.
How to install: viewtopic.php?f=6&t=14509&sid=523868e80 ... 5f630b93c2
Die neue hwOS sport Firmware 10.75 ist jetzt zum kostenlosen Download verfügbar:
Die folgenden Änderungen wurden gemacht:
[10.75]
BUGFIX: Die Auflösung der Gewebedruckberechnungen wurde erhöht, um sehr geringe Druckunterschiede zwischen Umgebungs- und Gewebedruck zu erfassen.
ÄNDERUNG: Bei OSTC mit mechanischen (magnetischen) Tasten müssen zum Aufwachen beide Tasten gedrückt werden
ÄNDERUNG: Unterstützung für neue OSTC+ Hardware mit O2-Sensoreingängen
ÄNDERUNG: Anpassung der maximalen Helligkeitseinstellungen
ÄNDERUNG: Zurücksetzen der Planungsparameter auf die Standardwerte, aber nur beim Aufrufen des Menüs.
Dadurch bleiben die Einstellungen zwischen mehreren Rechenläufen erhalten
FIX: die Ausgabe der Berechnungsergebnisse war in mehrere Schritte unterteilt, was bei
die bei kooperativem Multitasking unterbrochen werden konnten. Dadurch konnte es zu Störungen in der
Bildschirmausgabe auftreten, wenn z.B. der TTS auf NDL umschaltet, aber der Deko-Daten-Flag-Vektor
noch nicht aktualisiert wurde. Jetzt kann die Kompilierung aller Berechnungsergebnisse nicht mehr
unterbrochen werden.
[10.73]
BUGFIX: Korrekte Aktualisierung der Entsättigungszeit und der Gewebedaten nach einem Batteriewechsel (nur OSTC mit vom Benutzer austauschbaren Batterien)
NEU: Option zur Unterdrückung unkritischer Warnungen im Tauchmodus
ÄNDERUNG: Die Option gas6 wird im alternativen Layout nicht angezeigt (Wechseln Sie zum normalen Layout, um das Gas 6 während des Tauchgangs zu konfigurieren)
ÄNDERUNG: Teile des RX-Menüs im Tank-Setup werden nicht angezeigt, wenn keine RX-Hardware vorhanden ist
ÄNDERUNG: Low-Level-Code-Verbesserungen für mehr Leistung
[10.72]
NEU: Unterstützung für die aktuelle Hardware-Version von OSTC 2, plus und Sport
- ein Reset Bluetooth aus dem Reset-Menü kann erforderlich sein, um BLE/Bluetooth 4.0 zu aktivieren
[10.71]
BUGFIX: Sensorerkennung in OSTC plus konnte bei einigen Hardware-Versionen fehlschlagen
BUGFIX: Die Berechnung von Zeit/Datum des Tauchgangsendes im Logbuchbildschirm bei Tauchgängen mit viel Oberflächenzeit/vielen Abstiegen
NEW: Unterschiedliche Helligkeitseinstellungen für Tauch- und Oberflächenmodus
NEW: Kleine Änderungen in den verschiedenen Sprachversionen
BUGFIX: Stromverbrauch im Schlafmodus reduziert
[10.70]
NEU: Unterstützung für neuen Drucksensor in OSTC 2 und plus
NEU: Sprachupdates
ÄNDERUNG: Verhalten beim Wechsel auf inaktive Gase
BUGFIX: Hintergrundbeleuchtung konnte unter bestimmten Bedingungen pulsieren
NEU: In der Großansicht wird das Tauchmodus-Menü in großer Schrift (Eine Zeile) dargestellt
[10.68]
NEU: Unterstützung für aktuelle Platinen-Version im OSTC2 und plus
BUGFIX: Abbruch bei unbekannten parametern während der Bluetooth-Konfiguration via App
ÄNDERUNG: Eine Begriffe im Menü wurden präzisiert
ÄNDERUNG: Für die LS14500 SAFT (T0) (Nur im OSTC sport) und für die 16650 (T4) im OSTC 2 wurde die Sicherheitsmarge bei der Kapazitätsberechnung erhöht
[10.67]
CHANGE: Updates bei der Französischen Sprachversion
[10.66]
BUGFIX: Verbesserte Berechnungsgenauigkeit des Erstaufstiegs. Bemerkung: dies wird einen leichten Einfluss auf den resultierenden Dekoplan haben, verglichen mit der 10.64
ÄNDERUNG: Das Menüsystem zum Einrichten des Tauchmodus und der Einstellungen wurde aufgeräumt. Alle Einstellungen sind jetzt in die Gruppen TG-Einstellungen sortiert, Dekompression, SAC (Gasbedarf)-Einstellung, O2 Partialdruck und Stopps und Tiefen.
NEU: Für TG mit Firmware >= 10.66 wird im Logbuch noch eine weitere Detailseite mit Sättigunsdaten angezeigt
NEU: Eine neue Firmware-Wiederherstellungsfunktion wurde hinzugefügt: die derzeit aktive Firmware kann gesichert und später wiederhergestellt werden, während andere Firmwares geladen wurden. Die Funktion ist zugänglich über Konfiguration -> System -> Reset Menü -> Neustart/Backup und wird mit dem ersten Laden einer Firmware verfügbar nach der 10.66 (oder später).
CHANGE: Bei Betrieb mit einer 3,6-V-Batterie (entweder austauschbar oder eingebaut) wird der Timeout auf 4 Minuten vor dem Einschlafen verlängert. Bei 1,5V Batterien bleibt es bei 90 um die Batterie zu schonen
NEU: Aktualisiert OSTC 2 TR-Computer auf RX-Firmware 1.40
[10.64]
[10.63]
BUGFIX: Der flache Bereich am TG-Ende wurde nicht zum Oberflächenintervall addiert
BUGFIX: Die Durschnittstiefe im Logbuch wurde ohne den eingestellten Salzgehalt angezeigt
CHANGE: Temperaturwerte im Logbuch werden jetzt in gelb angezeigt.
Es enthält die RX firmware 1.41 für alle OSTC 2 TR Benutzer.
Bitte Fragen zum Update/Probleme beim Update in einem neuen Thread posten.
[10.75]
interrupted.
[10.74]
[10.73]
[10.72]
[10.71]
[10.70]
[10.68]
[10.67]
[10.66]
[10.64]
[10.63]
[10.75]
[10.73]
[10.72]
[10.71]
[10.70]
NEU: Sprachupdates
[10.68]
[10.67]
[10.66]
[10.64]
[10.63]
