New 3.16 Firmware
Posted: 24 Oct 2023, 11:02
Today, we released the 3.16 stable for the USB-OSTC2 Series (2N/Mk.2/2C).
Changes since 3.00 (Changes since 3.13):
BUGFIX: Vertical speed display
NEW: Allow to set date > 31.12.2020
BUGFIX: Small language fixes
CHANGE: Debug mode disabled (Hard-coded)
BUGFIX: Fix licence in German
1. Get new bootloader v2: https://hwdiving.com/firmwares/
2. Follow the step-by-step instructions: viewtopic.php?f=2&t=4071
Heute haben wir die Version 3.15 stable für die USB-OSTC2 Serie (2N/Mk.2/2C) veröffentlicht.
1. Neuen bootloader v2 herunterladen: https://hwdiving.com/firmwares/
2. Die einfache Schritt-für-Schritt Anleitung befolgen: viewtopic.php?f=2&t=4071
Best Regards,
Re: New 3.16 Firmware
Posted: 07 Apr 2026, 12:53
by koe1968
Hi. I tried to update my OSTC 2C today from v3.15 to v3.16 but now the display has frozen with the text "Bootloader Please wait!" and the blue light on the back is flashing. How can I get it working again ?
Posted: 09 Apr 2026, 12:47
This is a bit tricky, but you can restore it using the ^‘Bootloader v1’ on Windows: viewtopic.php?t=4071
> If firmware version <1.90 is still installed:
> - Download Bootloader v1
> - Select OSTC, Mk.2/2N/2C
> - Click on ‘Update Firmware’
> - Select the HEX file
> - Restart the device via ‘reboot’ and within 5 seconds:
> - Click OK and wait approx. 30 seconds:
> Notes:
> 2. If the ‘Reboot OSTC’ menu option is no longer available (e.g. because incorrect firmware has been installed), the reset to start the bootloader can also be performed using a magnet on the back of the OSTC. The magnet and ‘Reboot OSTC’ have exactly the same effect.
> 3. Under no circumstances should you perform a magnet reset during the update (red LED flashing – or ‘Please Wait’ appears)!
Important: Use bootloader v1, not v2.
Posted: 11 Apr 2026, 17:10
by koe1968
Thanks for the help - it worked and I back to 3.15 and everything works :-)
Posted: 12 Apr 2026, 13:16
There are no known issues with this 3.16, so update to 3.16 and I'm sure it will work fine with your 2C then.
