New 3.16 Firmware
New 3.16 Firmware
Today, we released the 3.16 stable for the USB-OSTC2 Series (2N/Mk.2/2C).
Changes since 3.00 (Changes since 3.13):
BUGFIX: Vertical speed display
NEW: Allow to set date > 31.12.2020
BUGFIX: Small language fixes
CHANGE: Debug mode disabled (Hard-coded)
NEW: Logbook shows markers with small orange boxes in the profile
BUGFIX: Minor layout fix (Battery warning in divemode)
CHANGE: Color-code battery % display in surface mode (Charge, Full, Normal)
BUGFIX: "First Diluent" and "SP Mode" used same EEPROM location
CHANGE: Battery percent based on ON-Time instead of battery voltage
BUGFIX: Fix licence in German
BUGFIX: Fix minor layout bugs in surface mode
NEW: Auto Setpoint switch function (CC Modes)
BUGFIX: 1st line in logbook was not displayed in rare cases (2C hardware)
BUGFIX: Divetime had unwanted "." behind the minutes
BUGFIX: Entry time in logbook when dive was around midnight
BUGFIX: Show manually set O2 (Gas 6) correctly
BUGFIX: Show dives with >999mins divetime correctly
BUGFIX: Fix color codes 192-223 (Mk.2 and 2N only)
Updating is very easy if you have 1.90 or later and using Windows.
1. Get new bootloader v2: https://hwdiving.com/firmwares/
2. Follow the step-by-step instructions: viewtopic.php?f=2&t=4071
Heute haben wir die Version 3.15 stable für die USB-OSTC2 Serie (2N/Mk.2/2C) veröffentlicht.
Das Updaten auf die neue Version ist sehr einfach, wenn bereits 1.90 oder später installiert ist und Windows verwendet wird.
1. Neuen bootloader v2 herunterladen: https://hwdiving.com/firmwares/
2. Die einfache Schritt-für-Schritt Anleitung befolgen: viewtopic.php?f=2&t=4071
Best Regards,
koe1968
Re: New 3.16 Firmware
Post by koe1968 »
Hi. I tried to update my OSTC 2C today from v3.15 to v3.16 but now the display has frozen with the text "Bootloader Please wait!" and the blue light on the back is flashing. How can I get it working again ?
This is a bit tricky, but you can restore it using the ^‘Bootloader v1’ on Windows: viewtopic.php?t=4071
> If firmware version <1.90 is still installed:
> - Download Bootloader v1
> - Select OSTC, Mk.2/2N/2C
> - Click on ‘Update Firmware’
> - Select the HEX file
> - Restart the device via ‘reboot’ and within 5 seconds:
> - Click OK and wait approx. 30 seconds:
> Notes:
> 2. If the ‘Reboot OSTC’ menu option is no longer available (e.g. because incorrect firmware has been installed), the reset to start the bootloader can also be performed using a magnet on the back of the OSTC. The magnet and ‘Reboot OSTC’ have exactly the same effect.
> 3. Under no circumstances should you perform a magnet reset during the update (red LED flashing – or ‘Please Wait’ appears)!
Important: Use bootloader v1, not v2.
koe1968
Post by koe1968 »
Thanks for the help - it worked and I back to 3.15 and everything works :-)
There are no known issues with this 3.16, so update to 3.16 and I'm sure it will work fine with your 2C then.
