Currently, I'm using an OSTC+ much to my pleasure. The unit works fine but there's one thing I miss.
When resetting average depth, a stopwatch also appears. However, would it be possible to add the stopwatch separate from the reset avg function?
This way, deco-stop time can be measured as well as other timing things without needing to reset the average depth.
Feature request: Normal stopwatch
Re: Feature request: Normal stopwatch
You have two average depth readings. One, that is for the entire dive and the other one is linked to the stopwatch. So even if you don't need the stoppable average depth, you still have the one for the whole dive.
