hwOS TECH: New Firmware 3.24
The new hwOS tech (for OSTC3, OSTC plus, OSTC+, cR, OSTC 2 and OSTC sport (mod. 19)) firmware 3.24 is now available for download:
Using OSTC+ or OSTC cR with external O2-Monitoring? Make sure to install the firmware with "_cr_" in the file name to keep the O2-Monitoring option available!
[3.24]
CHANGE: Add voltage-based battery meter for OSTC+/PLUS when inserting batteries with unknown SOC
CHANGE: Language updates
BUGFIX: Release and "Update" dates fixed
[3.22]
FIX: minor fix of 12h time update in dive mode
NEW: Add charge cycle counter
NEW: Add surface customview 11: NoFly, Desat and CNS
NEW: Show # of descends in Apnoe mode
CHANGE: do not show the "slow" in the alternative layout
CHANGE: minor adjustment of depth position in large layout
[3.21]
FIX: Wrong release date in 3.20 showed "Update!" message prematurely
CHANGE: Reduce default bottom time for simulator from 10' to 2'
FIX: BLE was on after first reboot (until sleepmode kicks in)
[3.20]
Bugfix: Some USB hardware version showed USB mode insetad of BLE Mode
[3.19]
CHANGE: OSTC with mechanical (magnetic) buttons need both buttons beeing pressed to wake up
interrupted.
[3.18]
[3.17]
[3.16]
[3.15]
NEW: Big dive mode menu in big layout view
BUGFIX: fix pulsing brightness in ECO on some hardware versions
CHANGE: support for internal hardware changes
CHANGE: adjust gas density parameters to match upcoming new ISO standard
Die neue hwOS tech Firmware 3.24 (für OSTC3, OSTC plus, OSTC+, cR, OSTC 2 und OSTC sport (mod. 19)) ist jetzt zum kostenlosen Download verfügbar:
Du verwendest einen OSTC+ oder OSTC cR mit externem O2-Monitoring? Installiere unbedingt die Firmware mit „_cr_“ im Dateinamen, damit die O2-Monitoring-Option verfügbar bleibt!
[3.24]
[3.22]
FIX: Kleine Korrektur in der 12h-Zeitanzeige (AM/PM) im Tauchmodus
NEW: Ladezykluszähler hinzugefügt
NEW: Benutzerdefinierte Oberflächenansicht 11 hinzugefügt: NoFly, Desat und CNS
NEW: Anzeige der Anzahl der Tauchgänge im Apnoe-Modus
ÄNDERUNG: das "slow" wird im alternativen Layout nicht mehr angezeigt
ÄNDERUNG: Kleine Anpassung der Tiefenposition im großen Layout
[3.21]
FIX: Falsches Veröffentlichungsdatum in 3.20 zeigte verfrüht "Update!
CHANGE: Kompatibilität für neue Hardware-Versionen
ÄNDERUNG: Standard-Bottomtime für den Simulator von 10' auf 2' reduziert
FIX: BLE war nach dem ersten Neustart eingeschaltet (bis der Sleepmode einsetzte)
[3.20]
Bugfix: Einige USB-Hardware-Versionen zeigten den USB-Modus anstelle des BLE-Modus
[3.19]
unterbrochen werden.
[3.18]
[3.17]
[3.16]
[3.15]
NEU: Sprachupdates
Bitte Fragen zum Updateprozess/Probleme beim Update in einem neuen Thread posten.
Re: hwOS TECH: New Firmware 3.24
The firmware file names (NNN_LL_2_tr_ostc3_firmware.hex or NNN_LL_3_cr_ostc3_firmware.hex) do not clearly reflect the OSTC to which a particular file applies. Could this be changed in the future ?
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
Yves
Post by Yves »
I was on Release 3.23 on an OSTC Plus loaded with hitech SW until september 2024. It worked OK with the new battery I had to changed because yours was HS after 2 years. Then in October this year I decide to install the Release 3.24 as advised before I leave for dive holiday in Madagascar.
I noticed something stranged when I wanted to charge the battery with a pad. Actually, I have two pads which gave the same behaviour.
After the dive, OSTC showed 40% remaining. I put it on the pad.
After a couple of seconds, it shows 100% load, amazing. I removed the pad, turned on the OSTC that showed 60%.
I put it again on the pad that displayed 100% after less than a second. I removed the pad, turned on the OSTC that showed 20% then 40% in less than a second.
I put it back on the pad that displayed again 100%. I left it for nearly one hour showing 100%, then the OSTC showed 60%. I continued on the pad, the OSTC showed 80%, never above, as the pad was fixed on 100%.
I dived with it. After the dive I turned on the OSTC the check the Log book. The load was 80% at the beginning and after checking the log book, it became 60%, after a couple of seconds.
OSTC always displayed these values and never intermediate values (eg 61, 62, 63, etc)
I wonder if there is not a problem with Release 3.24
Would you be king enough to check the changes between Release 3.23 and 3.24, to see if there is something to fix.
Best Regards,
Yves
Continue here: viewtopic.php?t=22563
