hwOS TECH: New Firmware 3.26
Posted: 19 Dec 2024, 18:13
The new hwOS tech (for OSTC3, OSTC plus, OSTC+, cR, OSTC 2 and OSTC sport (mod. 19)) firmware 3.26 is now available for download:
Using OSTC+ or OSTC cR with external O2-Monitoring? Make sure to install the firmware with "_cr_" in the file name to keep the O2-Monitoring option available!
[3.26]
MD5: 16e150139c3b28af38b24a05f87c0b86
BUGFIX: Year in internal Time/Date menu was limited to 2024
[3.25]
BUGFIX: Firmware recovery for hardware versions xxxx-xx05
BUGFIX: Plain Bühlmann (non-GF) could show a stop 0min @ 0m
CHANGE: Color design updated in surface mode
NEW: Additional customview Desat/NoFly/CNS added in surface mode
[3.24]
CHANGE: Add voltage-based battery meter for OSTC+/PLUS when inserting batteries with unknown SOC
CHANGE: Compatibility for new hardware versions
CHANGE: Language updates
BUGFIX: Release and "Update" dates fixed
[3.22]
FIX: minor fix of 12h time update in dive mode
NEW: Add charge cycle counter
NEW: Add surface customview 11: NoFly, Desat and CNS
NEW: Show # of descends in Apnoe mode
CHANGE: do not show the "slow" in the alternative layout
CHANGE: minor adjustment of depth position in large layout
[3.21]
FIX: Wrong release date in 3.20 showed "Update!" message prematurely
CHANGE: Reduce default bottom time for simulator from 10' to 2'
FIX: BLE was on after first reboot (until sleepmode kicks in)
[3.20]
Bugfix: Some USB hardware version showed USB mode insetad of BLE Mode
[3.19]
BUGFIX: Increase resolution of tissue pressure calculations to track very low pressure differences between ambient and tissue pressures
CHANGE: OSTC with mechanical (magnetic) buttons need both buttons beeing pressed to wake up
CHANGE: Support for new OSTC+ hardware with O2 sensor inputs
CHANGE: Adjust max. brightness settings
CHANGE: reset planning parameters to default values - only when entering the menu,
thus keeping the settings between multiple calculator runs
FIX: the output of the calculation results was divided into several steps, which
could be interrupted in cooperative multitasking. So glitches could occur in the
screen output if e.g. the TTS switched to NDL but the deco data flag vector was
not updated yet. Now the compilation of all calculation results can no longer be
interrupted.
[3.18]
Die neue hwOS tech Firmware 3.26 (für OSTC3, OSTC plus, OSTC+, cR, OSTC 2 und OSTC sport (mod. 19)) ist jetzt zum kostenlosen Download verfügbar:
Du verwendest einen OSTC+ oder OSTC cR mit externem O2-Monitoring? Installiere unbedingt die Firmware mit „_cr_“ im Dateinamen, damit die O2-Monitoring-Option verfügbar bleibt!
[3.26]
[3.25]
[3.24]
[3.22]
FIX: Kleine Korrektur in der 12h-Zeitanzeige (AM/PM) im Tauchmodus
NEW: Ladezykluszähler hinzugefügt
NEW: Benutzerdefinierte Oberflächenansicht 11 hinzugefügt: NoFly, Desat und CNS
NEW: Anzeige der Anzahl der Tauchgänge im Apnoe-Modus
ÄNDERUNG: Kompatibilität für neue Hardware-Versionen
ÄNDERUNG: das "slow" wird im alternativen Layout nicht mehr angezeigt
ÄNDERUNG: Kleine Anpassung der Tiefenposition im großen Layout
[3.21]
FIX: Falsches Veröffentlichungsdatum in 3.20 zeigte verfrüht "Update!
CHANGE: Kompatibilität für neue Hardware-Versionen
ÄNDERUNG: Standard-Bottomtime für den Simulator von 10' auf 2' reduziert
FIX: BLE war nach dem ersten Neustart eingeschaltet (bis der Sleepmode einsetzte)
[3.20]
Bugfix: Einige USB-Hardware-Versionen zeigten den USB-Modus anstelle des BLE-Modus
[3.19]
BUGFIX: Die Auflösung der Gewebedruckberechnungen wurde erhöht, um sehr geringe Druckunterschiede zwischen Umgebungs- und Gewebedruck zu erfassen.
ÄNDERUNG: Bei OSTC mit mechanischen (magnetischen) Tasten müssen zum Aufwachen beide Tasten gedrückt werden
ÄNDERUNG: Unterstützung für neue OSTC+ Hardware mit O2-Sensoreingängen
ÄNDERUNG: Anpassung der maximalen Helligkeitseinstellungen
ÄNDERUNG: Zurücksetzen der Planungsparameter auf die Standardwerte, aber nur beim Aufrufen des Menüs.
Dadurch bleiben die Einstellungen zwischen mehreren Rechenläufen erhalten
FIX: die Ausgabe der Berechnungsergebnisse war in mehrere Schritte unterteilt, was bei
die bei kooperativem Multitasking unterbrochen werden konnten. Dadurch konnte es zu Störungen in der
Bildschirmausgabe auftreten, wenn z.B. der TTS auf NDL umschaltet, aber der Deko-Daten-Flag-Vektor
noch nicht aktualisiert wurde. Jetzt kann die Kompilierung aller Berechnungsergebnisse nicht mehr
unterbrochen werden.
[3.18]
BUGFIX: Korrekte Aktualisierung der Entsättigungszeit und der Gewebedaten nach einem Batteriewechsel (nur OSTC mit vom Benutzer austauschbaren Batterien)
NEU: Option zur Unterdrückung unkritischer Warnungen im Tauchmodus
ÄNDERUNG: Die Option gas6 wird im alternativen Layout nicht angezeigt (Wechseln Sie zum normalen Layout, um das Gas 6 während des Tauchgangs zu konfigurieren)
ÄNDERUNG: Teile des RX-Menüs im Tank-Setup werden nicht angezeigt, wenn keine RX-Hardware vorhanden ist
ÄNDERUNG: Low-Level-Code-Verbesserungen für mehr Leistung
[3.17]
NEU: Unterstützung für die aktuelle Hardware-Version von OSTC 2, plus und Sport
- ein Reset Bluetooth aus dem Reset-Menü kann erforderlich sein, um BLE/Bluetooth 4.0 zu aktivieren
How to install: viewtopic.php?f=6&t=14509
Re: hwOS TECH: New Firmware 3.25
Posted: 08 Jan 2025, 10:41
by cyberdiamond
From website:
Shows
[3.25]
MD5: 885bd199f7f25b37ed339471fe9778f2
Here is what I get:
steve@t14:~$ wget https://heinrichsweikamp.com/media/wysi ... rmware.zip
Saving 'v_325_hwos_firmware.zip'
HTTP response 200 [https://heinrichsweikamp.com/media/wysi ... rmware.zip]
v_325_hwos_firmware. 100% [===========================================================================================================================================================================================>] 1.31M 668.92KB/s
[Files: 1 Bytes: 1.31M [342.12KB/s] Redirects: 0 Todo: 0 Errors: 0 ]
steve@t14:~$
steve@t14:~$ md5sum v_325_hwos_firmware.zip
87f9d26fa1f72da79b9303ba05de42db v_325_hwos_firmware.zip
Can see the MD5 checksum is different and I have tried multiple times through a web browser or cli is the same?
Posted: 08 Jan 2025, 10:53
The checksum is historically the checksum of the English version of the firmware. So the file hwos_tech_firmware_EN.hex.
Here are the current MD5 checksums for the other versions:
fcbcd9e7d9ee38e1727b1f6505c29537 hwos_tech_firmware_DE.hex
885bd199f7f25b37ed339471fe9778f2 hwos_tech_firmware_EN.hex
5f88475783ca6c880b4429365c8ba4e1 hwos_tech_firmware_FR.hex
f6662c48756206ad60465aea6d0f27e1 hwos_tech_firmware_IT.hex
357323b815ff43e434a24b957d18face hwos_tech_o2_sensor_firmware_DE.hex
9cdfbd1e568d9f1c3472e4c9270c8a8c hwos_tech_o2_sensor_firmware_EN.hex
39ed1a3bb86d18736bf76b8170fc990c hwos_tech_o2_sensor_firmware_FR.hex
632568d382867577c4c189ce55bfe5cb hwos_tech_o2_sensor_firmware_IT.hex
Posted: 08 Jan 2025, 10:59
by cyberdiamond
The reason I am checking it is I got a scrambled screen towards the end of the (first and only) dive on it after an update to 3.25 (was on 3.22 before)
Here is a screen grab showing what it looked like just after I cleared my 12m deco stop (It happen before that time but this is when I got a video of it):
Posted: 08 Jan 2025, 11:02
by cyberdiamond
See if this one is a bit clearer?
Posted: 08 Jan 2025, 11:03
That's a failing screen and is not software related.
Posted: 08 Jan 2025, 11:04
by cyberdiamond
I tried a simulation of the dive, just on the surface a short time ago and it all looked ok.
Posted: 08 Jan 2025, 11:08
From this picture, your OSTC 3 looks quite "used"... Maybe we should have a look at this here?
Posted: 08 Jan 2025, 11:17
by cyberdiamond
It has done a lot of caves dives so the outside does get scratched up!
I will send you an email and we can continue then.
Posted: 14 Jan 2025, 14:15
by scubatinoo
Besten Dank, Update ist problemlos durchgelaufen. Das Colordesign ist ok, auch wenn "grün" nicht meine Lieblingsfarbe ist...
Eine Bitte für eine der nächsten Versionen: "Bluetooth Modus" dürfte gerne etwas prominenter in der Menü-Struktur eingeordnet werden... Die Funktion ist mittlerweile fast die am häufigsten gewählte...
Re: hwOS TECH: New Firmware 3.26
Posted: 11 Jul 2025, 19:15
by LaFosca
Hallo
Ich habe die hwOS TECH Firmware auf meinem OSTC2 (>2022) auf 3.26 aktualisiert und bekomme nun den "Akkufehler": Akku war zwar voll geladen, ist nach dem Update aber runter auf 6%. Laut FAQ ist dieser Fehler dadurch zu beheben, dass der "CF74" auf "3600" zu setzen ist. Aber wie stellt man das an? Über HWOS Config lassen sich die CF nicht bearbeiten, und über OSTC Config ( PC/Windows) bekomme ich keine Bluetooth Verbindung mit dem OSTC2 zustande.
Was bleibt übrig?
Einschicken?
LG aus Spanien
Christian aka LaFosca
Posted: 11 Jul 2025, 22:18
Einfach mal auf dem Lader liegen lassen bis 100% grün unterlegt sind. Dann passt es wieder.
Posted: 12 Jul 2025, 09:31
by LaFosca
Hallo Matthias
Besten Dank, werde ich tun🙂
Posted: 31 Aug 2025, 16:46
Continue here: viewtopic.php?t=22612
