hwOS TECH: New Firmware 3.28
The new hwOS tech (for OSTC3, OSTC plus, OSTC+, cR, OSTC 2 and OSTC sport (mod. 19)) firmware 3.28 is now available for download:
Using OSTC+ or OSTC cR with external O2-Monitoring? Make sure to install the firmware with "_cr_" in the file name to keep the O2-Monitoring option available!
[3.28]
MD5: f7960ecc2f353361dcf7e598dd460cc6
BUGFIX: Compass on very old OSTC 3 hardware was inactive in the 3.27
[3.27]
MD5: 33bbe464b0d76a59dd6833167244dbe8
NEW: Quicker startup
CHG: Slightly reduce sleep mode consumption
NEW: Compass now uses much larger font for heading display, removed clutter and graphics making the compass more useful
NEW: Compass uses dedicated stopwatch. It's reset and restarted when a course is set
NEW: Temperature still shown during compass use
[3.26]
MD5: 16e150139c3b28af38b24a05f87c0b86
BUGFIX: Year in internal Time/Date menu was limited to 2024
[3.25]
BUGFIX: Firmware recovery for hardware versions xxxx-xx05
BUGFIX: Plain Bühlmann (non-GF) could show a stop 0min @ 0m
CHANGE: Color design updated in surface mode
NEW: Additional customview Desat/NoFly/CNS added in surface mode
[3.24]
CHANGE: Add voltage-based battery meter for OSTC+/PLUS when inserting batteries with unknown SOC
CHANGE: Language updates
BUGFIX: Release and "Update" dates fixed
[3.22]
FIX: minor fix of 12h time update in dive mode
NEW: Add charge cycle counter
NEW: Add surface customview 11: NoFly, Desat and CNS
NEW: Show # of descends in Apnoe mode
CHANGE: do not show the "slow" in the alternative layout
CHANGE: minor adjustment of depth position in large layout
[3.21]
FIX: Wrong release date in 3.20 showed "Update!" message prematurely
CHANGE: Reduce default bottom time for simulator from 10' to 2'
FIX: BLE was on after first reboot (until sleepmode kicks in)
[3.20]
Bugfix: Some USB hardware version showed USB mode insetad of BLE Mode
[3.19]
CHANGE: OSTC with mechanical (magnetic) buttons need both buttons beeing pressed to wake up
interrupted.
[3.18]
Die neue hwOS tech Firmware 3.28 (für OSTC3, OSTC plus, OSTC+, cR, OSTC 2 und OSTC sport (mod. 19)) ist jetzt zum kostenlosen Download verfügbar:
Du verwendest einen OSTC+ oder OSTC cR mit externem O2-Monitoring? Installiere unbedingt die Firmware mit „_cr_“ im Dateinamen, damit die O2-Monitoring-Option verfügbar bleibt!
[3.28]
[3.27]
[3.26]
[3.25]
[3.24]
[3.22]
FIX: Kleine Korrektur in der 12h-Zeitanzeige (AM/PM) im Tauchmodus
NEW: Ladezykluszähler hinzugefügt
NEW: Benutzerdefinierte Oberflächenansicht 11 hinzugefügt: NoFly, Desat und CNS
NEW: Anzeige der Anzahl der Tauchgänge im Apnoe-Modus
ÄNDERUNG: das "slow" wird im alternativen Layout nicht mehr angezeigt
ÄNDERUNG: Kleine Anpassung der Tiefenposition im großen Layout
[3.21]
FIX: Falsches Veröffentlichungsdatum in 3.20 zeigte verfrüht "Update!
CHANGE: Kompatibilität für neue Hardware-Versionen
ÄNDERUNG: Standard-Bottomtime für den Simulator von 10' auf 2' reduziert
FIX: BLE war nach dem ersten Neustart eingeschaltet (bis der Sleepmode einsetzte)
[3.20]
Bugfix: Einige USB-Hardware-Versionen zeigten den USB-Modus anstelle des BLE-Modus
[3.19]
unterbrochen werden.
[3.18]
[3.17]
Bitte Fragen zum Updateprozess/Probleme beim Update in einem neuen Thread posten.
