hwOS Sport: New Firmware 10.87
The new hwOS sport firmware 10.87 is now available for download:
[10.87]
MD5: 5fa4887027e28b191d430e6b14eda905
BUGFIX: After a power-on reset, some hardware versions would enter divemode delayed for the first dive
[10.86]
MD5: 0c212537b9bfbed27747131596c0999d
BUGFIX: Compass on very old OSTC 3 and OSTC sport hardware was inactive in the 10.85
[10.85]
MD5: 2c968419b06814bbbb460d5734949cd3
NEW: Quicker startup
CHG: Slightly reduce sleep mode consumption
NEW: Compass now uses much larger font for heading display, removed clutter and graphics making the compass more useful
NEW: Compass uses dedicated stopwatch. It's reset and restarted when a course is set
NEW: Temperature still shown during compass use
[10.84]
MD5: fda91be1860a75466588bf8e8570fdcd
[10.82]
MD5: bdf4a01b06774e4fab5b4624b966384b
BUGFIX: Year in internal Time/Date menu was limited to 2024
[10.81]
BUGFIX: Firmware recovery for hardware versions xxxx-xx05
BUGFIX: Plain Bühlmann (non-GF) could show a stop 0min @ 0m
CHANGE: Color design updated in surface mode
NEW: Additional customview Desat/NoFly/CNS added in surface mode
[10.80]
CHANGE: Add voltage-based battery meter for OSTC+/PLUS when inserting batteries with unknown SOC
CHANGE: Language updates
BUGFIX: Release and "Update" dates fixed
[10.77]
NEW: Descent counter for Apnoe mode
NEW: Dedicated surface customview #11 for Desat-Time, No-Fly and CNS
FIX: NDL was shown in normal layout once deco was cleared in large layout
NEW: Charge Cycle counter in Information menu
[10.76]
FIX: Wrong release date in 10.75 showed "Update!" message prematurely
[10.75]
interrupted.
[10.74]
CHANGE: OSTC with mechanical (magnetic) buttons need both buttons being pressed to wake up
CHANGE: minor changes in the different language versions
BUGFIX: Bluetooth Reset option for 2022 OSTC sport models fixed
[10.73]
[10.72]
[10.71]
[10.70]
[10.68]
[10.67]
CHANGE: French language fixes
[10.66]
[10.64]
Die neue hwOS sport Firmware 10.87 ist jetzt zum kostenlosen Download verfügbar:
[10.87]
[10.86]
[10.85]
[10.84]
[10.82]
[10.81]
[10.80]
ÄNDERUNG: Hinzufügen einer spannungsbasierten Batterieanzeige für OSTC+/PLUS beim Einlegen von Batterien mit unbekanntem Ladezustand
ÄNDERUNG: Verbesserungen bei den Texten
BUGFIX: Freigabe- und „Update“-Datum korrigiert
[10.77]
NEU: Tauchgangszähler für Apnoe-Modus
NEU: Dedizierte Oberflächenansicht #11 für Desat-Time, No-Fly und CNS
BUGFIX: NDL wurde im normalen Layout angezeigt, wenn die Deko im großen Layout abgelaufen war
NEU: Ladezyklenzähler im Informationsmenü
[10.76]
FIX: Falsches Veröffentlichungsdatum in 10.75 zeigte "Update!"
[10.75]
unterbrochen werden.
[10.73]
[10.72]
[10.71]
[10.70]
NEU: Sprachupdates
[10.68]
[10.67]
[10.66]
[10.64]
