3.31 beta Version with Surface GF
Posted: 25 Nov 2025, 16:34
Hi all,
Attached to this post is the 3.31 beta1 for all hwOS TECH enabled OSTC. This version got a new custom view in dive mode with Saturation (Called "GF99" by others), Ceiling and Surface GF.
Surface GF is computed for all GF-Deco modes (OC/CCR) during the dive and indicates the oversaturation in the leading tissue for an instantaneous ascend to the surface.
Beta Versions require manual installation via the OSTC Companion or Subsurface as described here: viewtopic.php?f=6&t=14509
Happy testing,
Re: 3.31 beta 2 Version with Surface GF and Scrubber Timer
Posted: 14 Dec 2025, 13:22
Attached is the 3.31 beta2 for all hwOS TECH enabled OSTC. Surface GF has been improved, some Bugfixes were made for the display of the Surface GF.
New is the "Scrubber timer" sub-menu in the CCR menu. Note: For debugging purposes the CCR Scrubber timer is currently count-down in the simulator mode, as well.
Remaining: The remaining Scrubber time in minutes
Restart Scrubber: Resets Scrubber time to configured time
Timer enabled: YES/NO
Scrubber time: The max. scrubber time (increments in 10 minute steps
Happy testing,
Re: 3.31 beta Version with Surface GF
Posted: 15 Dec 2025, 06:00
Posted: 16 Dec 2025, 21:31
by Nordicdive.de
The menu point calibrate sensors is gone :shock:
Not testable software, so far
Posted: 19 Dec 2025, 18:15
Here's this version with external O2 monitoring enabled (Attached).
Posted: 04 Jan 2026, 14:04
This feature was added to the 3.32: viewtopic.php?t=22672
