I've a mk1 OSTC with v1.60 on it
I tried today the new CF42, with the blinking of the current gaz if a better gaz is available. It worked as expected, but I find that the blinking doesn't attract too much the attention to it (not so visible) - I would like to have a more visible blinking.
Suggestions :
- faster blinking
- currently the display blinks between "current gaz displayed" and "nothing displayed" - maybe it will be more visible with a blinking between "current gaz displayed" and the same but with reversed video or something like that
David
Gas blinking
Re: Gas blinking
I ran some simulations yesterday and noticed that with an active gas and switching depth of 9m the blinking didn't work at 9m at all.
When I went to 6m it started blinking around 8,5m.
Steve
CMAS 2* Instructor
Belgium
CMAS 2* Instructor
Belgium
Re: Gas blinking
Hello Steve,
That's intend. The blinking starts if you miss your gas change. We'll try to make this more eye catching in the next 1.61beta. The idea with the normal/inverted output might be a good idea (and is easy to implement).
Dangerous Dave
Re: Gas blinking
Sounds good.
Sounds good.
Hubertus
Re: Gas blinking
wie muss ich das Gas-Blinken einstellen ???? muss das bei punkt 42 auf 1 oder 10 Stehen ???
Danke
Danke
