Gas blinking
Posted: 02 May 2010, 18:10
by David Boileau
I've a mk1 OSTC with v1.60 on it
I tried today the new CF42, with the blinking of the current gaz if a better gaz is available. It worked as expected, but I find that the blinking doesn't attract too much the attention to it (not so visible) - I would like to have a more visible blinking.
Suggestions :
- faster blinking
- currently the display blinks between "current gaz displayed" and "nothing displayed" - maybe it will be more visible with a blinking between "current gaz displayed" and the same but with reversed video or something like that
David
Re: Gas blinking
Posted: 04 May 2010, 07:34
by Steve
I ran some simulations yesterday and noticed that with an active gas and switching depth of 9m the blinking didn't work at 9m at all.
When I went to 6m it started blinking around 8,5m.
Re: Gas blinking
Posted: 04 May 2010, 19:40
Hello Steve,
That's intend. The blinking starts if you miss your gas change. We'll try to make this more eye catching in the next 1.61beta. The idea with the normal/inverted output might be a good idea (and is easy to implement).
Re: Gas blinking
Posted: 04 May 2010, 20:12
by David Boileau
Great !
Re: Gas blinking
Posted: 05 May 2010, 14:40
by Dangerous Dave
Sounds good.
Re: Gas blinking
Posted: 06 May 2010, 09:04
by Hubertus
wie muss ich das Gas-Blinken einstellen ???? muss das bei punkt 42 auf 1 oder 10 Stehen ???
Danke
Re: Gas blinking
Posted: 06 May 2010, 12:29
by Steve
auf 1
