I tested the computer this weekend. When I want to import the data in jdivelog, it doesn't seem to work. On the ostc, I can see 5 dives (2 test dives from HeinrichsWeikamp, 1 simulated dive in jdivelog and 2 real dives). When I put 'import' in jdivelog, only the two test dives from HeinrichtsWeikamp seem to work, i.e., they show up in the import window of jdivelog. The third dive - this is the dive I simulated in jdivelog - and fourth and fifth don't show up so I can't import them. What can be the cause of this? (Wrong data storage somehow due to simulation in jdivelog? Can I remove this dive? ...?)
Thanks, Kurt
jdivelog - import problem
kurt.sys
Re: jdivelog - import problem [SOLVED]
see 'import/clear memory?'-thread.
Kurt
Kurt
