pb with temperature
Posted: 24 Sep 2010, 06:36
by jujube
the temperature given by my MK2 is + 4° than "real" compare with 3 other sensors
Re: pb with temperature
Posted: 24 Sep 2010, 10:48
Are you charging the unit while reading the temperature? This causes some degrees difference because of losses in the charging circuit. If the unit is not attached to USB and temperature has stabilized with the room temperature you won't see much difference to other sensors.
Posted: 24 Sep 2010, 16:56
by jujube
the difference is during the dives... not in my room... strange
Posted: 02 Oct 2010, 22:27
by Mike
Hallo, Ich habe das gleiche problem, letzte grosse Tauchgang, 35' zwiechen 35 und 47m, und hatte 12° als anzeige in einem See wo die Températur bei 4-6° ist.
Posted: 08 Nov 2010, 09:47
by Mike
Hat jemanden info über wie man die Temperatur richtig einstellen kann ?
Habe immer noch 3-4° mehr als das richtige asser oder Raum températur ?
MFG
Mike
