GF & Deep Stops
Bago
GF & Deep Stops
Post by Bago »
Hi, this is my first post.
I have just bought my new OSTC MK2 and dived with it last sunday for the first time.
I dived to 67m with OC mode without GF.
The OSTC MK2 presented no Deep Stops, is it a matter of no GF set up ?
Wich is the best setting to have deep stops ?
Thank you, your computer is awesome !!!
dmainou
Re: GF & Deep Stops
Post by dmainou »
From the MK2 website:
http://www.heinrichsweikamp.com/en/ostc_mk2/
What this OSTC Mk.2 dive computer is not:
Competition for cheap mass products for the occasional diver.
What this OSTC Mk.2 dive computer is:
An experimental platform for all experienced divers who are interested in the theory of diving and who value maximum transparency and individual adaptabily .
you need to understand what the computer is doing even if you don't know how to program.
Then you can get the computer to give you the deco profile that YOU want.
buy this book and read it:
http://www.dive-tech.co.uk/deco%20for%20divers.htm
It is meant for divers rather than mathematicians so I can guarantee that you will enjoy it.
Then read this.
http://www.decompression.org/baker/home.htm
# username: downloadfiles
# password: decompression1
Especially "undestanding M values" and "clearing up the confussion about deep stops"
It is an FTP so you'll need the details above to surf
The big picture is also sumarised in here.
http://www.rebreatherworld.com/general- ... mmies.html
Hope it helps.
D
OSTC MK2 1394
Bago
Re: GF & Deep Stops
Post by Bago »
Thx D
Anyway My question was a prelude to ask why we can't modify GF over 90 and under 30 ...
I will read out your book and maybe I will find out
Re: GF & Deep Stops
If you not sure what gradient factors are please start with the default values. They offer enough safety and are tested in the field intensively for the most standard dives (e.g. 60m with a deco gas). Aggressive settings like GF_high=100 can be used in special environments like caves but require a deeper understanding and a lot experience in decompression dives.
Re: GF & Deep Stops
Hi Bago,
i agree to the previous answers.
To give you a rough and brief idea here some more information.
In order to generate deep stops with the MK2 you need to activate GF.
The lower you set the first value the deeper the first stop is.
The lower you set the second value the longer the shallow stops are.
If you like very deep first stops you can select the first value as low as 5 but you should not set it bigger then 30.
The first value set to 30 doesn't really generate deep stops.
The second value shouldn't be set higher then 90. To generate longer shallow stops you may choose 85 or 80.
So a good GF-setting to start with is 20/85.
For deeper first stops use GF 10/85 or 5/85.
For longer shallow stops with a more shallow first stop you may choose 25/80 or 30/75.
So the first value should be set to 5 - 30, the second value should be set to 75 - 90.
To check different profiles you may use the simulator or any GF-based desktop-software like V-planner and so on.
Before using GF-settings read some more of the previously linked information.
Be safe and know what you are doing, Reiner
Bago
Re: GF & Deep Stops
Post by Bago »
Thank you all... your answers tell me I landed in the right place !
In fact dive OC no GF and OC with GF set to 30/90 gives you the same deco
profile and no deep first stops.
Sunday I was diving with several friends (6) with GF standard setting 30/90 we noticed no big difference and no stops at deep.
Anyway I will surely read and study the OSTC, the book and links...
Thanks again, Bago.
dmainou
Re: GF & Deep Stops
Post by dmainou »
> the right place !
> book and links...
> Thanks again, Bago.
Hi Bago,
That is not accurate at all. The GF completely modifies the approach to the M Value.
Maybe you are simply modelling too shallow or too little bottom time. If you are attempting 3 minutes at 40 it is likely that most algorythms will tell you that no stops are required. However that doesn't mean that they arrived to the conclusion in the same way.
It also doesn't mean that you don't need to do any stops but decompression theory is is a matter to discuss elsewhere.
Try doing a simulation with a deeper and longer bottom time. You'll see the difference.
As per my first post, PLEASE do not play with the settings if you do not understand what you are doing. This computer does let you in command. Therefore, it is very important that you understand what you are doing.
Enjoy the book.
D
OSTC MK2 1394
Bago
Re: GF & Deep Stops
Post by Bago »
Yes You are right since it was the first dive we made with OSTC we planned really short Bottom time ... I will try the simulator and check but I agree
Bago
Re: GF & Deep Stops
Post by Bago »
D
Your user & psw for [www.decompression.org] does not work
Do you have new ones or do you know why ?
dmainou
Re: GF & Deep Stops
Post by dmainou »
Bago Wrote:
> D
> Your user & psw for does not work
Click on the ftp link and use the username and password previously provided.
They are revamping the website so not everything works.
http://www.decompression.org/maiken/VPM ... ations.htm
Once you are in go to Baker's folder. There is a lot more info but it is likely to be of little use to you until you understand a bit more. Also some theories differ to the theory behind the OSTC. So unless you wish to change to a different computer... By all means learn about the other theories but I would start with Mr Haldane > Workman > Buhlman > Baker's Gradient Factors.
The concepts behind the first three are very well covered on the "deco for divers" book. (However there is little to no math on the book). Baker's papers are on the FTP.
D
OSTC MK2 1394
dmainou
Re: GF & Deep Stops
Post by dmainou »
The two articles you are looking for is:
"Understanding M-Values.pdf"
Then read
"Deep Stops.pdf"
However if you read this first you are really starting by the end.
D
OSTC MK2 1394
Iain
Re: GF & Deep Stops
Post by Iain »
I just tried reading the documents at decompression.org but the user name and password did not appear to be working. Have these changed?
Iain.
Touchwood
Re: GF & Deep Stops
Post by Touchwood »
It worked for me using FileZilla as an ftp client. Are you attempting to connect directly from your browser? Internet Explorer is rubbish for this.
OSTC 2N #2791
wrobell
Re: GF & Deep Stops
Post by wrobell »
i believe you can find the same documents at
dmainou
Re: GF & Deep Stops
Post by dmainou »
I just tried.
Everything is there and password works. Firefox over Ubuntu Linux. straight through.
D
OSTC MK2 1394
