deep stops
eddy
deep stops
Post by eddy »
Wie tief Haltestellen oder sehen, was cf.. Ich muss etwas ändern, so dass die OSTC-mk2 berechnet. In O/C -Modus.
How deep stops on, or see what cf.. I must change something, so the OSTC-mk2 computed (calculate). In O/C mode
Solodiver
Re: deep stops
Post by Solodiver »
Eddy, what do you mean? To enable GF (including deep stops as you might meaning it) you have to choose the OC GF deco modelin the OSTC setup, this has nothing to do with CF. Dependend on the choosen GF (set in CF 32 and 33) your deco stops are calculated, if you like to have "deeper" deep stops you should define a "lower" GF low (CF 32)
HTH
