gas list / first gas diluent for ccr
i have another suggetions.
Would it be possible to change the software to enable using another gas from the gas-list for ccr-diluent beside the 1st gas in constant ppo2-mode?
At present you have to change the first gas in order to use a different diluent for a different dive.
So if you want to change from air to let's say 10/60 you have to push 171 times the right button.
To change the first gas with a PC via the interface is not an option as I do not carry my laptop onto the rib but sometimes we have to change plans after leaving the harbour and i do carry Trimix and Air diluent cylinders all the time.
Re: gas list / first gas diluent for ccr
The next beta will have more comfort in changing values in the Gas Setup or Custom Functions. Pressing and holding down the right button will automatically increase the current value.
Simon A
Post by Simon A »
Matthias,
Thanks for the information. Will holding down the right button cause the value to increase for as long as the button is held in, or will it be along the lines of short press =1 and long press =10?
Simon
As long as you keep the button pressed, the value is increased. There is a delay of about one second before the counting starts.
