Changing default gases in 1.90?
Posted: 26 Jun 2011, 12:12
by PeterK
I'd like to change the default settings for the gases since they are kind of funny. For example my gas 1 default is 0/10. I dont think I'm ever going to dive this kind of gas :-)
Re: Changing default gases in 1.90?
Posted: 26 Jun 2011, 22:23
by Solodiver
AFAIR this could be set in jdivelog!? Can't test it due my box is running 1.91 already :-)
Posted: 26 Jun 2011, 22:43
by sailor
for my unit all gases are default 21/0.
I have version 1.90 loaded aswell.
Posted: 27 Jun 2011, 13:20
by PeterK
Did not try jdivelog as I normally use divinglog. THis software shows no option to change the defaults.
Checked it again, my defaults are not 21/0.
Any advise?
Posted: 27 Jun 2011, 14:01
PeterK Wrote:
> Any advise?
Hi Peter,
You can also reset the defaults with 'Reset -> Reset all Gases, CF and Deco'
Posted: 27 Jun 2011, 22:08
by PeterK
Dear Matthias,
thanks for the response. What happens to my customized CFs when using the recommended reset function?
Posted: 28 Jun 2011, 20:02
by PeterK
Thanks Matthias, resetting gases solved the issue. By saving my CFs to the binary file and later restore I managed to restore all my personal settings.
Great stuff.
Posted: 28 Jun 2011, 22:41
by david tobin
How do you write the CFs to binary in Diving Log
I have set the option to true in the advanced settings but what do I next?
Posted: 28 Jun 2011, 22:51
by PeterK
In the same window you'll find the path where the binary is stored. The default setting is using one of the user specific directories of windows. However, as these are named differently in english and german I cant tell what it looks like in your system. Kepp in mind that the default path is hidded, so you cant see in the explorer. Anyway, you can select any patch you want, e.g. the desktop.
Now you have Divinlog to read data from the OSTC. This will generate the binary. Check its presence. Now you can reset your OSTC. Once the reset is completed change the Divinglog setting to Writetobinary=No and Readfrombinary=Yes. Now go to the options, make one change to activate the Write to OSTC-Button. That's it. Have fun.
Posted: 28 Jun 2011, 23:29
by david tobin
Thank you will now have a play
