1.19 Beta (English)
1.19 Beta (English)
The beta 1.19 is now available, as last! Compared to the 1.17 stable we improved several options and added features requested here in the Forum.
http://www.heinrichsweikamp.net/ostc/en ... 14E109.htm
Major changes:
- Decompression calculations with the GF method. The two parameters GF_lo and GF_hi can be configured with the Custom Functions CF32 and CF33. The decomodes with Deep Stops are now called "L16 GF OC" for Open Circuit divers and "L16 GF CC" for (semi-) closed rebreathers. To add the GF method some major changes in the decomodule were made and this beta may still contain bugs. Consider this when diving with this beta!
- New Submenus.
"O2 Sensor Menu" and "Int. Modules Menu" do not have much functionality yet. They were added for the module developers. "Custom Functions II" contains the new CF32-CF63
- Battery symbol.
In Surfacemode a new battery symbol can replace the voltage level, configure with CF31.
- New Gas Setup.
Just try it. It's much more comfortable now. In every menu where you had to push the button very often you can now press and hold the button to change the values.
We're interested in feedback (Positive and Negative)!
With kind regards,
