Hi guys, I'm a new user of the Mk2, i'm quite happy with it, I used to have a Sol and do deco with EAN75.
I managed to set up the new tank on the Mk2 and put it active but i cant find the following information :
When I reach the limit of 11m, how do I swap gas on my OSTC ? I dont find the info in the manual.
Thanks you
New to Mk2n - Changing gas during dive
Re: New to Mk2n - Changing gas during dive
In divemode you have underwater menu available. Press left (Menu?) -> right (Enter), select "Gaslist", select your gas (left button) and confirm with right (Enter).
It's actually self-explanatory while diving.
I taught if that, but I taught it was a bit complicated (many manipulations)
thanks !
thanks !
@karuko:
I've also moved from the Sol to the OSTC. I was also looking for a quicker way to change gases. However, I've been told that this is a policy of Heinrichs-Weikamp to have a 3 button protocol here.
However, after very few dives I'm completely used to this. After all, the menus are very easy to read,understand and to follow.
Peter
OSTC 2N #2338
Peter
OSTC 2N #2338
i've read thats the point…
Tried yesterday and its really easy anyway
I wish it was easier to see when the limit is reached and that we can can change gas, the small star, is well small
I wish some it was more eye-catch
There is a CF that makes the current gas flashing when a better one is available.
Peter
OSTC 2N #2338
Peter
OSTC 2N #2338
Which one ??
http://www.heinrichsweikamp.com/en/ostc ... functions/
CF42:Blink gas
Setting this value to 1 will blink the current gas if a better gas is available and was configured for this dive.
Recommended range: 0 or 1 (0=Normal, 1=Blinking)
Default setting: 0 (Normal)
Example: CF41=1 - The current gas will blink if a better gas is available for this depth.
CF42:Blink gas
rettet euch selbst
Thanks a lot !!
big up !
big up !
