Hello
What is the countdown as in the photo? It appears for 2 to 3 seconds during the ascent when the depth is between 1 m and the surface. Mathias thank you for your clarification.
cordially
Xav ...
Question on V2.00
Chilihead
Re: Question on V2.00
[pre]
CF02:delay in s for end of dive mode
This value sets the time the OSTC will wait before switching into surfacemode after a dive. The time will be reset if the OSTC is below the threshold set in CF01.
Recommend range: 120 ... 240 (120s to 240s)
Default setting: 240 (240s)
Example: CF02=120 - After two minutes above the threshold set in CF01 the OSTC will switch to surfacemode.
[/pre]
[pre]
CF02:Delay in s für Tauchmodus Ende
Dieser Wert gibt an wie lange (in Sekunden) der OSTC oberhalb der in CF01 eingestellten Tiefe warten soll bevor der Tauchgang beendet und der Oberflächenmodus aktiviert wird.
Empfohlener Wertebereich: 120 ... 240 (120s...240s)
Grundeinstellung: 240 (240s)
Beispiel: CF02=120 - Nach zwei Minuten oberhalb der in CF01 eingestellten Tiefe wird der aktuelle Tauchgang beendet.
[/pre]
of course in Simulator-Mode you can see the countdown only 2 oder 3 seconds... then the simulation ends...
[/pre]
[pre]
[/pre]
rettet euch selbst
