I updated my OSTC Mk2 to version 2.0 a couple of days ago. I then dived the next day, two dives. I could see the two dives in the logbook on my OSTC no problem, as well as all my older dives.
I try to download them to JDivelog and all I get is one dive from 4 months ago!
I update JDivelog to version 2.16 and I still only see one dive on my OSTC from 4 months ago when I try to download.
I backdate my OSTC to V1.90 and the two dives are gone! However I can now see all my dives stored in the logbook when I try to download them to JDivelog.
So I have just updated my OSTC to V2.0 again and JDivelog now sees all my old dives.
The two dives from yesterday are still gone though.......
Is this a bug or just a bad install?
Neil
V2.0 Logbook Bug?
Re: V2.0 Logbook Bug?
Loosing your dives when downgrading to 1.90 is described in the release notes. So nothing to worry about. Reason for that is the change in internal logbook format beyond V1.90. This might also be the reason behind the troibles with JDiveLog. However, since I'm not using this software I cannot comment.
Peter
OSTC 2N #2338
Peter
OSTC 2N #2338
This could also be related to one of the beta versions between 1.90 and 2.00 (Did you use them?).
NeilBedwin
No, I did not use any beta versions.
I went from v1.9 to v2.0.
I am not so worried about losing my dives (I have them on my VRx) but the fact that no dives, except for one 4 months old, showed up when I tried to download to JDivelog. They were all in the logbook on the OSTC but JDivelog only saw the one!
Now that I have downgraded and upgraded back to v2.0 JDivelog sees all the dives on the OSTC so it may have been a bad install.
I am not diving this weekend as my wife is dragging me out shopping in Dubai
But I will repost the week after once I have been in the water again.
Neil
Neil
I had a similar issue. I upgrade my 2N from V1.9 to V2.0 and then connected the OSTC to import my dives.
There where no dives showing up into the dive log screen.
I upgraded my dive log from 5.0 to the 5.0.5 version.
Then I redid the operation and then my dives showed up into the dive log screen. I was able to import them and now I see them into my logbook.
MacGuyver
MacGuyver
