CF56 &CF57 Message
Posted: 17 Sep 2011, 19:59
by Yogi
Having just upgraded my firmware from 1.8 to V2.00, my front screen has a red box in the Top RH of the screen showing alternately, CF56! and CF57!
When I go to the configure screen on Diving Log 5.0, I can only see CF 1 - 31?
How do I fix this?
Re: CF56 &CF57 Message
Posted: 17 Sep 2011, 21:36
by JeanDo
Directly on the OSTC, go to menu setup 2, and reset CF56 & CF57 to default values.
Posted: 17 Sep 2011, 22:34
Hi Yogi,
Its a bug with Diving Log. Read this forum thread at Diving Log.
OSTC 2N V2.0 Custome Functions
There you will find a patch to make CFII visible again in Diving Log.
As for the actual "problem" with CF56 & CF57 follow JD's advice.
Posted: 17 Sep 2011, 23:45
by Yogi
Thanks guys,. That helped a lot.
Posted: 18 Sep 2011, 01:12
by Regthing
Hi Steve. Broke it already?
Posted: 18 Sep 2011, 10:57
by Yogi
Sure have Scott!;)
On another note, is it possible to delete a dive from the OSTC? I was playing with it on the plane and set the altimeter to ON. When the pressure rose on landing it logged a 2 hour dive at 1.6M until I managed to reset it again on the 2nd flight. (Then said I couldn't fly for 24 hours!)
I know I can delete it from Diving Log 5.0 but it would be better to remove it completely.
Steve
Posted: 19 Sep 2011, 12:52
by Jean-François
Sadly you cannot delete only 1 dive. You can reset the whole logbook though.
