Beta 1.21
Beta 1.21
...this Firmware is now available for download http://www.heinrichsweikamp.net/ostc/en ... 3C6DD3.htm and includes a few new Features as well as some small Bugfixes.
...diese Firmware kann nun geladen werden http://www.heinrichsweikamp.net/ostc/de ... 3C6DD3.htm und enth?lt einige neue Funktionen und ein paar kleinere Bugfixes.
Gruss,
Matthias Heinrichs
HeinrichsWeikamp
Gruss,
Matthias Heinrichs
HeinrichsWeikamp
nicolas schreyer
Re: Beta 1.21
> http://www.heinrichsweikamp.net/ostc/de/0115114F88
> 1DD49028B941471C48773C6DD3.htm und enth?lt einige
welche Bug ??
welche Bug ??
Re: Beta 1.21
nicolas schreyer Wrote:
> welche Bug ??
Haupts?chlich wurden die Ausgaberoutinen etwas ?berarbeitet. Im Tauchmodus haben einige Ausgaben das Men? leicht ?berschrieben.
An den Dekoroutinen wurden bei diesem Update keine ?nderungen durchgef?hrt.
Gruss,
> welche Bug ??
Gruss,
servan
Re: Beta 1.21
I've got a problem with the logbook.
When I want to see the profile, I've only have three pixels and I have to reset the OSTC...
Servan
Servan
Re: Beta 1.21
Hello Servan,
Did the profile view worked fine with the previous version? I do not see a problem with the profile view in the 1.21.
servan
Re: Beta 1.21
Hello Matthias
> version?
Yes
> view in the 1.21.
I'll "downgrade" the firmware version...
Servan
> version?
Yes
> view in the 1.21.
Servan
Re: Beta 1.21
What I found out, when upgrading from the stable to the 1.21 beta the new dimmed display feature starts in dark mode (Default should be Normal/Bright mode).
We're thinking of releasing a new stable soon...
nicolas schreyer
Re: Beta 1.21
> Hello,
> Regards,
> Matthias
I upgraded mine from 1.20 to 1.21, the display started on mode "dark" too...
could itt be possible to add this display switch mode in the surface menu ?
> Hello,
> Regards,
> Matthias
Re: Beta 1.21
Easiest way would be a custom function (CF37) which is toggled with the UW-Menu as well as with the CF II menu....
servan
Re: Beta 1.21
servan Wrote:
> Hello Matthias
> previous
> > version?
> Yes
> > view in the 1.21.
I "downgrade" to 1.20 and the profile view work fine.
I upgrade 1.20 to 1.21 the profile view is still bugging.
I'll stay with 1.20
Servan
> Hello Matthias
> previous
> > version?
> Yes
> > view in the 1.21.
I'll stay with 1.20
Servan
Re: Beta 1.21
Does this happen with every dive or only with a particular dive in your logbook? We have tested the 1.21 Logbook on all our rental units and could not reproduce this error.
servan
Re: Beta 1.21
I've got the problem only with the 2 last dives in the logbook.
Am I alone in the world with this bug
Servan
Servan
Re: Beta 1.21
Do you use Divinglog? This software can dump a Hex file of your logbook (Advanced Settings - WriteToBinary). If you send me this file I'll see if there is a problem with this two dives.
servan
Re: Beta 1.21
Hello
I use JDivelog. But I can't download this two dives because I can't see them...
Today I dive two times. No problem with the profile view in the logbook and JDivelog.
Servan
Servan
nicolas schreyer
Re: Beta 1.21
servan Wrote:
> Hello,
> the logbook.
> Regards
> Servan
oui
> Hello,
> the logbook.
> Regards
> Servan
oui
Re: Beta 1.21
Bonjour,
Hard to tell from here what's wrong with the two dives. I would recommend that you delete the entire internal logbook memory with the "Delete all" function (Which you can access in the Profileview Menu). This will format the memory. New dives will be added without problems. You can replay some older dives in the simulator to get them back into the OSTC.
divinglog
Re: Beta 1.21
[quote]I use JDivelog. But I can't download this two dives because I can't see them... [/quote]
Hi Servan
You can download the dives even if you can't see them. When you enable the "WriteToBinary" option in Diving Log it will store the whole binary data received from the OSTC, no matter if the data is corrupt or not. This makes it possible to view the data in a hex viewer and see what the problem could be. This works also on the unregistered version of Diving Log.
Kind regards,
Sven
Hi Servan
Kind regards,
Sven
servan
Re: Beta 1.21
Bonjour Mathias
> Profileview Menu).
I did it and it's ok now.
I suppose it is the sampling rate, but I'm not sure and I can't reproduce the bug...
Sven, I have deleted the logbook before reading your post.
Mathias, Sven, thanks a lot for your help.
Servan
> Profileview Menu).
Servan
