Hello everyone,
My question is, is it possible to change the OCR gas using to a personel setting ??
Peter
gas using
Re: gas using
"change the OCR gas using to a personel setting"
i don't understand
what do you want to do ?
i don't understand
DCG peter
Re: gas using
What I ment is;
When you make a planning in the simulater mode, you fill in the bottom time and
the Max. Depth, then you choose Calculate deco.
When you have your deco time and stops you can tap the right button and you get the OCR Gas Usage.
On what are these ......ltr. of gas are based ??, and can I change these to my
personal SAC for bottom and deco gas.
Peter
Peter
Re: gas using
Yes, this is liters.
You can configure CF56 (bottom SAC) and CF57 (deco SAC).
They both defaults to 20 L/min.
PS: Actually, if you want cuft/min, the OSTC don't mind: it just multiply by the value you setup in CF56/CF57.
