Three bugs(?) in Firmware 2.20 / Drei Käfer(?) in Firmware 220
Posted: 13 Feb 2012, 09:18
Hi there,
i found some bugs in Firmware Version 220.
First:
The easy one: in EEProm Bank 0 the "total number of cf used in firmware" is wrong!
I recieve 58.
But this was never the number of CF in Firmware, this was always "the last CF in firmware".
CF counting starts with 0 not with 1 (this seems to be a major problem in all the descriptions, not only with CF (perhaps also in code?).
Second:
In my last dive i got an never ending stop at 21m.
(maybe this is related to http://www.heinrichsweikamp.com/read.php?2,7782)
I did a sililar dive before were the stop times were ok.
What was different:
I prepared my OSTC with the following gases:
Selected Gas at begin of dive (2): 21/30
Gas 1: 12/55
Gas 2: 21/30
Gas 3: 31/35
Gas 4: 49/0 at 21m
Gas 5: 100/0 at 6m
Gas 6: 30/0
The Gasses 2, 4, 5 where shown as used (color in the gaslist)
Active Gases were 2,3,4,5
But i decieded to use gas 2,3 and 5 during the dive
At 37m i changed the gas to Gas no 3 (TMX 31/35).
Third:
At the end of the dive i provoked some ppo2 high warnings
one warning i got is at 6,35m thats ok bit in the following i have several times when i was deeper then this and i recieved NO warning in the logfile.
Here is the profile data of the dive and my CF Settings.
regards
Servus miteinander,
ich habe ein paar bugs in Firmware Version 2.20 gefunden.
Erstens:
Der leichte
in EEPROM Bank 0 das byte für "total number of cf used in firmware" ist falsch.
Ich erhalte hier 58 als Wert, eigentlich sollten es 60 sein.
Aber der Eintrag war ja noch nie dir Anzahl der CF in der Firmware, es war vielmehr die letzte CF Nummer der Firmware.
Das Zählen der CF startet bei 0 und nicht bei 1 (Aber das Zählproblem des StartBytes zieht sich durch die gesamte Dokumentation, nicht nur bei den CF (vieleicht auch im Code?)
Zweitens:
Bei meinem letzten Tauchgang hatte ich einen nicht endenden Stop bei 21m.
(ich denke das passt auch zu http://www.heinrichsweikamp.com/read.php?2,7782)
Bei einem ähnlichen Tauchgang war heir alles ok.
Der Unterschied war:
Ich stellte folgende Gase am OSTC ein:
Gewähltes Gas bei TG beginn (2): 21/30
Gas 1: 12/55
Gas 2: 21/30
Gas 3: 31/35
Gas 4: 49/0 bei 21m
Gas 5: 100/0 bei 6m
Gas 6: 30/0
Gas Nummer 2, 4, 5 wurden als genutzte Gase angezeigt (Farbe in der Gasliste).
Aktive Gase waren 2,3,4,5
Ich entschied mich aber die Gase 2,3 and 5 für den Tauchgang zu verwenden.
Auf 37m wechselte ich zu Gas Nr. 3 (TMX 31/35).
Drittens:
Am Ende des Tauchgangs provutierte ich ein paar ppO2 high warnings.
eine Warnung erhielt ich auf 6,35m, das ist ja ok, aber im Folgenden war ich einige male tiefer als die 6,35m und im Logzeitgte sich keine ppO2 Warnung.
Grüße
Hier noch die Profildaten und die Custom Functions.
Filename: 0794_11-02-2012_060m_063min
DiveFileversion: 100
LogBookProfileVersion: 33
DiveNumber: 794
Date of dive: 11.02.2012
Time at begin of dive: 12:13:00
Time at end of dive: 13:17:00
Maximum depth (mbar): 6047
Maximum depth (bar): 6,047
Divetime: 63min 39sec
Gas 1: 12/55
Gas 2: 21/30
Gas 3: 31/35
Gas 4: 49/0
Gas 5: 100/0
Gas 6: 30/0
Minimum water temperature: 3,1
Surface air pressure (mBar): 932
Desaturation time after dive (min): 677
Maximum CNS (%): 42
Average depth: 2123 mbar
Total divetime: 4059 sec.
GFLo: 30
GFHi: 80
Decotype: ZH-L16-GF OC
Firmware version: 220
Battery voltage in mV after dive: 4,144
Salinity: 1
Sampling rate (sec): 10
Sampling divisor temperature: 6 information size 32
Sampling divisor deco/NDL: 6 information size 32
Sampling divisor tank pressure: 0 information size 16
Sampling divisor ppO2 sensors: 0 information size 48
Sampling divisor deco debug: 8 information size 0
Profile data
ProfileOffset: 258
Number of ProfileEntries: 405
values after the | are byte the bytes starting at byte 3 (Profile Byte) shown as (hex)Binary
pos( 1) T: 0:00 D: 231 | (00)00000000
pos( 2) T: 0:10 D: 313 | (00)00000000
pos( 3) T: 0:20 D: 311 | (00)00000000
pos( 4) T: 0:30 D: 349 | (00)00000000
pos( 5) T: 0:40 D: 434 | (00)00000000
pos( 6) T: 0:50 D: 570 TEMP=32 Deco Stop at 0m Stop 240min | (04)00000100 (20)00100000 (00)00000000 (00)00000000 (F0)11110000
pos( 7) T: 1:00 D: 714 | (00)00000000
pos( 8) T: 1:10 D: 803 | (00)00000000
pos( 9) T: 1:20 D: 865 | (00)00000000
pos( 10) T: 1:30 D: 1017 | (00)00000000
pos( 11) T: 1:40 D: 1019 | (00)00000000
pos( 12) T: 1:50 D: 1090 TEMP=35 Deco Stop at 0m Stop 90min | (04)00000100 (23)00100011 (00)00000000 (00)00000000 (5A)01011010
pos( 13) T: 2:00 D: 1233 | (00)00000000
pos( 14) T: 2:10 D: 1291 | (00)00000000
pos( 15) T: 2:20 D: 1323 | (00)00000000
pos( 16) T: 2:30 D: 1356 | (00)00000000
pos( 17) T: 2:40 D: 1378 | (00)00000000
pos( 18) T: 2:50 D: 1425 TEMP=36 Deco Stop at 0m Stop 43min | (04)00000100 (24)00100100 (00)00000000 (00)00000000 (2B)00101011
pos( 19) T: 3:00 D: 1537 | (00)00000000
pos( 20) T: 3:10 D: 1626 | (00)00000000
pos( 21) T: 3:20 D: 1733 | (00)00000000
pos( 22) T: 3:30 D: 1748 | (00)00000000
pos( 23) T: 3:40 D: 1818 | (00)00000000
pos( 24) T: 3:50 D: 1807 TEMP=36 Deco Stop at 0m Stop 23min | (04)00000100 (24)00100100 (00)00000000 (00)00000000 (17)00010111
pos( 25) T: 4:00 D: 1790 | (00)00000000
pos( 26) T: 4:10 D: 1766 | (00)00000000
pos( 27) T: 4:20 D: 1810 | (00)00000000
pos( 28) T: 4:30 D: 1884 | (00)00000000
pos( 29) T: 4:40 D: 1954 | (00)00000000
pos( 30) T: 4:50 D: 2057 TEMP=36 Deco Stop at 0m Stop 16min | (04)00000100 (24)00100100 (00)00000000 (00)00000000 (10)00010000
pos( 31) T: 5:00 D: 2160 | (00)00000000
pos( 32) T: 5:10 D: 2239 | (00)00000000
pos( 33) T: 5:20 D: 2358 | (00)00000000
pos( 34) T: 5:30 D: 2461 | (00)00000000
pos( 35) T: 5:40 D: 2481 | (00)00000000
pos( 36) T: 5:50 D: 2589 TEMP=37 Deco Stop at 0m Stop 8min | (04)00000100 (25)00100101 (00)00000000 (00)00000000 (08)00001000
pos( 37) T: 6:00 D: 2626 | (00)00000000
pos( 38) T: 6:10 D: 2729 | (00)00000000
pos( 39) T: 6:20 D: 2855 | (00)00000000
pos( 40) T: 6:30 D: 2965 | (00)00000000
pos( 41) T: 6:40 D: 3062 | (00)00000000
pos( 42) T: 6:50 D: 3179 TEMP=38 Deco Stop at 0m Stop 4min | (04)00000100 (26)00100110 (00)00000000 (00)00000000 (04)00000100
pos( 43) T: 7:00 D: 3244 | (00)00000000
pos( 44) T: 7:10 D: 3325 | (00)00000000
pos( 45) T: 7:20 D: 3380 | (00)00000000
pos( 46) T: 7:30 D: 3435 | (00)00000000
pos( 47) T: 7:40 D: 3461 | (00)00000000
pos( 48) T: 7:50 D: 3505 TEMP=39 Deco Stop at 0m Stop 3min | (04)00000100 (27)00100111 (00)00000000 (00)00000000 (03)00000011
pos( 49) T: 8:00 D: 3540 | (00)00000000
pos( 50) T: 8:10 D: 3590 | (00)00000000
pos( 51) T: 8:20 D: 3680 | (00)00000000
pos( 52) T: 8:30 D: 3738 | (00)00000000
pos( 53) T: 8:40 D: 3811 | (00)00000000
pos( 54) T: 8:50 D: 3879 TEMP=39 Deco Stop at 0m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (00)00000000 (01)00000001
pos( 55) T: 9:00 D: 3966 | (00)00000000
pos( 56) T: 9:10 D: 4075 | (00)00000000
pos( 57) T: 9:20 D: 4168 | (00)00000000
pos( 58) T: 9:30 D: 4288 | (00)00000000
pos( 59) T: 9:40 D: 4378 | (00)00000000
pos( 60) T: 9:50 D: 4460 TEMP=38 Deco Stop at 6m Stop 1min | (04)00000100 (26)00100110 (00)00000000 (06)00000110 (01)00000001
pos( 61) T:10:00 D: 4559 | (00)00000000
pos( 62) T:10:10 D: 4639 | (00)00000000
pos( 63) T:10:20 D: 4671 | (00)00000000
pos( 64) T:10:30 D: 4798 | (00)00000000
pos( 65) T:10:40 D: 4891 | (00)00000000
pos( 66) T:10:50 D: 4991 TEMP=39 Deco Stop at 9m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (09)00001001 (01)00000001
pos( 67) T:11:00 D: 5092 | (00)00000000
pos( 68) T:11:10 D: 5171 | (00)00000000
pos( 69) T:11:20 D: 5196 | (00)00000000
pos( 70) T:11:30 D: 5270 | (00)00000000
pos( 71) T:11:40 D: 5374 | (00)00000000
pos( 72) T:11:50 D: 5511 TEMP=39 Deco Stop at 15m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (0F)00001111 (01)00000001
pos( 73) T:12:00 D: 5615 | (00)00000000
pos( 74) T:12:10 D: 5672 | (00)00000000
pos( 75) T:12:20 D: 5731 | (00)00000000
pos( 76) T:12:30 D: 5770 | (00)00000000
pos( 77) T:12:40 D: 5766 | (00)00000000
pos( 78) T:12:50 D: 5749 TEMP=39 Deco Stop at 15m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (0F)00001111 (01)00000001
pos( 79) T:13:00 D: 5833 | (00)00000000
pos( 80) T:13:10 D: 5830 | (00)00000000
pos( 81) T:13:20 D: 5889 | (00)00000000
pos( 82) T:13:30 D: 5912 | (00)00000000
pos( 83) T:13:40 D: 5884 | (00)00000000
pos( 84) T:13:50 D: 5832 TEMP=40 Deco Stop at 18m Stop 1min | (04)00000100 (28)00101000 (00)00000000 (12)00010010 (01)00000001
pos( 85) T:14:00 D: 5818 | (00)00000000
pos( 86) T:14:10 D: 5792 | (00)00000000
pos( 87) T:14:20 D: 5761 | (00)00000000
pos( 88) T:14:30 D: 5699 | (00)00000000
pos( 89) T:14:40 D: 5638 | (00)00000000
pos( 90) T:14:50 D: 5599 TEMP=40 Deco Stop at 21m Stop 1min | (04)00000100 (28)00101000 (00)00000000 (15)00010101 (01)00000001
pos( 91) T:15:00 D: 5545 | (00)00000000
pos( 92) T:15:10 D: 5513 | (00)00000000
pos( 93) T:15:20 D: 5533 | (00)00000000
pos( 94) T:15:30 D: 5499 | (00)00000000
pos( 95) T:15:40 D: 5427 | (00)00000000
pos( 96) T:15:50 D: 5387 TEMP=41 Deco Stop at 21m Stop 1min | (04)00000100 (29)00101001 (00)00000000 (15)00010101 (01)00000001
pos( 97) T:16:00 D: 5358 | (00)00000000
pos( 98) T:16:10 D: 5384 | (00)00000000
pos( 99) T:16:20 D: 5415 | (00)00000000
pos( 100) T:16:30 D: 5437 | (00)00000000
pos( 101) T:16:40 D: 5422 | (00)00000000
pos( 102) T:16:50 D: 5397 TEMP=41 Deco Stop at 21m Stop 1min | (04)00000100 (29)00101001 (00)00000000 (15)00010101 (01)00000001
pos( 103) T:17:00 D: 5386 | (00)00000000
pos( 104) T:17:10 D: 5356 | (00)00000000
pos( 105) T:17:20 D: 5322 | (00)00000000
pos( 106) T:17:30 D: 5246 | (00)00000000
pos( 107) T:17:40 D: 5161 | (00)00000000
pos( 108) T:17:50 D: 5097 TEMP=42 Deco Stop at 21m Stop 1min | (04)00000100 (2A)00101010 (00)00000000 (15)00010101 (01)00000001
pos( 109) T:18:00 D: 4990 | (00)00000000
pos( 110) T:18:10 D: 4924 | (00)00000000
pos( 111) T:18:20 D: 4862 | (00)00000000
pos( 112) T:18:30 D: 4750 | (00)00000000
pos( 113) T:18:40 D: 4737 | (00)00000000
pos( 114) T:18:50 D: 4703 TEMP=42 Deco Stop at 21m Stop 1min | (04)00000100 (2A)00101010 (00)00000000 (15)00010101 (01)00000001
pos( 115) T:19:00 D: 4547 | (00)00000000
pos( 116) T:19:10 D: 4432 | (00)00000000
pos( 117) T:19:20 D: 4325 | (00)00000000
pos( 118) T:19:30 D: 4209 | (00)00000000
pos( 119) T:19:40 D: 4137 | (00)00000000
pos( 120) T:19:50 D: 4038 TEMP=43 Deco Stop at 21m Stop 1min | (04)00000100 (2B)00101011 (00)00000000 (15)00010101 (01)00000001
pos( 121) T:20:00 D: 3934 | (00)00000000
pos( 122) T:20:10 D: 3821 | (00)00000000
pos( 123) T:20:20 D: 3811 | (00)00000000
pos( 124) T:20:30 D: 3875 | (00)00000000
pos( 125) T:20:40 D: 3814 | (00)00000000
pos( 126) T:20:50 D: 3773 TEMP=43 Deco Stop at 21m Stop 1min | (04)00000100 (2B)00101011 (00)00000000 (15)00010101 (01)00000001
pos( 127) T:21:00 D: 3777 | (00)00000000
pos( 128) T:21:10 D: 3761 | (00)00000000
pos( 129) T:21:20 D: 3733 | (00)00000000
pos( 130) T:21:30 D: 3738 | (00)00000000
pos( 131) T:21:40 D: 3721 gas Change to 1 no alarm | (82)10000010 (20)00100000 (01)00000001
pos( 132) T:21:50 D: 3730 gas Change to 3 no alarm TEMP=42 Deco Stop at 21m Stop 1min | (86)10000110 (20)00100000 (03)00000011 (2A)00101010 (00)00000000 (15)00010101 (01)00000001
pos( 133) T:22:00 D: 3680 | (00)00000000
pos( 134) T:22:10 D: 3595 | (00)00000000
pos( 135) T:22:20 D: 3463 | (00)00000000
pos( 136) T:22:30 D: 3340 | (00)00000000
pos( 137) T:22:40 D: 3253 | (00)00000000
pos( 138) T:22:50 D: 3173 TEMP=43 Deco Stop at 21m Stop 1min | (04)00000100 (2B)00101011 (00)00000000 (15)00010101 (01)00000001
pos( 139) T:23:00 D: 3075 | (00)00000000
pos( 140) T:23:10 D: 2973 | (00)00000000
pos( 141) T:23:20 D: 2910 | (00)00000000
pos( 142) T:23:30 D: 2814 | (00)00000000
pos( 143) T:23:40 D: 2724 | (00)00000000
pos( 144) T:23:50 D: 2633 TEMP=43 Deco Stop at 21m Stop 1min | (04)00000100 (2B)00101011 (00)00000000 (15)00010101 (01)00000001
pos( 145) T:24:00 D: 2523 | (00)00000000
pos( 146) T:24:10 D: 2400 | (00)00000000
pos( 147) T:24:20 D: 2311 | (00)00000000
pos( 148) T:24:30 D: 2212 | (00)00000000
pos( 149) T:24:40 D: 2279 | (00)00000000
pos( 150) T:24:50 D: 2373 TEMP=39 Deco Stop at 21m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (15)00010101 (01)00000001
pos( 151) T:25:00 D: 2456 | (00)00000000
pos( 152) T:25:10 D: 2446 | (00)00000000
pos( 153) T:25:20 D: 2359 | (00)00000000
pos( 154) T:25:30 D: 2263 | (00)00000000
pos( 155) T:25:40 D: 2198 | (00)00000000
pos( 156) T:25:50 D: 2146 TEMP=40 Deco Stop at 21m Stop 1min | (04)00000100 (28)00101000 (00)00000000 (15)00010101 (01)00000001
pos( 157) T:26:00 D: 2137 | (00)00000000
pos( 158) T:26:10 D: 2111 | (00)00000000
pos( 159) T:26:20 D: 2117 | (00)00000000
pos( 160) T:26:30 D: 2083 | (00)00000000
pos( 161) T:26:40 D: 2099 | (00)00000000
pos( 162) T:26:50 D: 2093 TEMP=39 Deco Stop at 21m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (15)00010101 (01)00000001
pos( 163) T:27:00 D: 2116 | (00)00000000
pos( 164) T:27:10 D: 2155 | (00)00000000
pos( 165) T:27:20 D: 2189 | (00)00000000
pos( 166) T:27:30 D: 2200 | (00)00000000
pos( 167) T:27:40 D: 2179 | (00)00000000
pos( 168) T:27:50 D: 2189 TEMP=39 Deco Stop at 21m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (15)00010101 (01)00000001
pos( 169) T:28:00 D: 2207 | (00)00000000
pos( 170) T:28:10 D: 2201 | (00)00000000
pos( 171) T:28:20 D: 2152 | (00)00000000
pos( 172) T:28:30 D: 2145 | (00)00000000
pos( 173) T:28:40 D: 2067 | (00)00000000
pos( 174) T:28:50 D: 2037 TEMP=39 Deco Stop at 21m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (15)00010101 (01)00000001
pos( 175) T:29:00 D: 2054 | (00)00000000
pos( 176) T:29:10 D: 2051 | (00)00000000
pos( 177) T:29:20 D: 2067 | (00)00000000
pos( 178) T:29:30 D: 2111 | (00)00000000
pos( 179) T:29:40 D: 2096 | (00)00000000
pos( 180) T:29:50 D: 2057 TEMP=39 Deco Stop at 21m Stop 1min | (04)00000100 (27)00100111 (00)00000000 (15)00010101 (01)00000001
pos( 181) T:30:00 D: 2018 | (00)00000000
pos( 182) T:30:10 D: 2045 | (00)00000000
pos( 183) T:30:20 D: 2047 | (00)00000000
pos( 184) T:30:30 D: 2073 | (00)00000000
pos( 185) T:30:40 D: 2032 | (00)00000000
pos( 186) T:30:50 D: 2058 TEMP=38 Deco Stop at 21m Stop 1min | (04)00000100 (26)00100110 (00)00000000 (15)00010101 (01)00000001
pos( 187) T:31:00 D: 2098 | (00)00000000
pos( 188) T:31:10 D: 2088 | (00)00000000
pos( 189) T:31:20 D: 2071 | (00)00000000
pos( 190) T:31:30 D: 2047 | (00)00000000
pos( 191) T:31:40 D: 1996 | (00)00000000
pos( 192) T:31:50 D: 1971 gas Change to 1 no alarm TEMP=39 Deco Stop at 21m Stop 1min | (86)10000110 (20)00100000 (01)00000001 (27)00100111 (00)00000000 (15)00010101 (01)00000001
pos( 193) T:32:00 D: 1949 gas Change to 1 no alarm | (82)10000010 (20)00100000 (01)00000001
pos( 194) T:32:10 D: 1899 gas Change to 2 no alarm | (82)10000010 (20)00100000 (02)00000010
pos( 195) T:32:20 D: 1789 | (00)00000000
pos( 196) T:32:30 D: 1652 | (00)00000000
pos( 197) T:32:40 D: 1506 | (00)00000000
pos( 198) T:32:50 D: 1524 TEMP=39 Deco Stop at 9m Stop 5min | (04)00000100 (27)00100111 (00)00000000 (09)00001001 (05)00000101
pos( 199) T:33:00 D: 1515 | (00)00000000
pos( 200) T:33:10 D: 1521 | (00)00000000
pos( 201) T:33:20 D: 1530 | (00)00000000
pos( 202) T:33:30 D: 1542 | (00)00000000
pos( 203) T:33:40 D: 1518 | (00)00000000
pos( 204) T:33:50 D: 1545 TEMP=38 Deco Stop at 9m Stop 4min | (04)00000100 (26)00100110 (00)00000000 (09)00001001 (04)00000100
pos( 205) T:34:00 D: 1553 | (00)00000000
pos( 206) T:34:10 D: 1603 | (00)00000000
pos( 207) T:34:20 D: 1632 | (00)00000000
pos( 208) T:34:30 D: 1672 | (00)00000000
pos( 209) T:34:40 D: 1629 | (00)00000000
pos( 210) T:34:50 D: 1670 TEMP=37 Deco Stop at 9m Stop 4min | (04)00000100 (25)00100101 (00)00000000 (09)00001001 (04)00000100
pos( 211) T:35:00 D: 1722 | (00)00000000
pos( 212) T:35:10 D: 1734 | (00)00000000
pos( 213) T:35:20 D: 1794 | (00)00000000
pos( 214) T:35:30 D: 1836 | (00)00000000
pos( 215) T:35:40 D: 1787 | (00)00000000
pos( 216) T:35:50 D: 1786 TEMP=38 Deco Stop at 9m Stop 3min | (04)00000100 (26)00100110 (00)00000000 (09)00001001 (03)00000011
pos( 217) T:36:00 D: 1747 | (00)00000000
pos( 218) T:36:10 D: 1742 | (00)00000000
pos( 219) T:36:20 D: 1713 | (00)00000000
pos( 220) T:36:30 D: 1703 | (00)00000000
pos( 221) T:36:40 D: 1694 | (00)00000000
pos( 222) T:36:50 D: 1664 TEMP=38 Deco Stop at 9m Stop 3min | (04)00000100 (26)00100110 (00)00000000 (09)00001001 (03)00000011
pos( 223) T:37:00 D: 1689 | (00)00000000
pos( 224) T:37:10 D: 1702 | (00)00000000
pos( 225) T:37:20 D: 1692 | (00)00000000
pos( 226) T:37:30 D: 1666 | (00)00000000
pos( 227) T:37:40 D: 1619 | (00)00000000
pos( 228) T:37:50 D: 1576 TEMP=39 Deco Stop at 9m Stop 2min | (04)00000100 (27)00100111 (00)00000000 (09)00001001 (02)00000010
pos( 229) T:38:00 D: 1479 | (00)00000000
pos( 230) T:38:10 D: 1445 | (00)00000000
pos( 231) T:38:20 D: 1418 | (00)00000000
pos( 232) T:38:30 D: 1398 | (00)00000000
pos( 233) T:38:40 D: 1387 | (00)00000000
pos( 234) T:38:50 D: 1333 TEMP=39 Deco Stop at 9m Stop 2min | (04)00000100 (27)00100111 (00)00000000 (09)00001001 (02)00000010
pos( 235) T:39:00 D: 1326 | (00)00000000
pos( 236) T:39:10 D: 1317 | (00)00000000
pos( 237) T:39:20 D: 1297 | (00)00000000
pos( 238) T:39:30 D: 1201 | (00)00000000
pos( 239) T:39:40 D: 1167 | (00)00000000
pos( 240) T:39:50 D: 1153 TEMP=41 Deco Stop at 9m Stop 1min | (04)00000100 (29)00101001 (00)00000000 (09)00001001 (01)00000001
pos( 241) T:40:00 D: 1115 | (00)00000000
pos( 242) T:40:10 D: 1072 | (00)00000000
pos( 243) T:40:20 D: 1066 | (00)00000000
pos( 244) T:40:30 D: 1094 | (00)00000000
pos( 245) T:40:40 D: 1049 | (00)00000000
pos( 246) T:40:50 D: 993 TEMP=41 Deco Stop at 6m Stop 13min | (04)00000100 (29)00101001 (00)00000000 (06)00000110 (0D)00001101
pos( 247) T:41:00 D: 997 | (00)00000000
pos( 248) T:41:10 D: 1021 | (00)00000000
pos( 249) T:41:20 D: 1040 | (00)00000000
pos( 250) T:41:30 D: 1098 | (00)00000000
pos( 251) T:41:40 D: 1096 | (00)00000000
pos( 252) T:41:50 D: 1074 TEMP=40 Deco Stop at 6m Stop 13min | (04)00000100 (28)00101000 (00)00000000 (06)00000110 (0D)00001101
pos( 253) T:42:00 D: 1063 | (00)00000000
pos( 254) T:42:10 D: 1063 | (00)00000000
pos( 255) T:42:20 D: 1005 | (00)00000000
pos( 256) T:42:30 D: 968 | (00)00000000
pos( 257) T:42:40 D: 1028 | (00)00000000
pos( 258) T:42:50 D: 1056 TEMP=39 Deco Stop at 6m Stop 13min | (04)00000100 (27)00100111 (00)00000000 (06)00000110 (0D)00001101
pos( 259) T:43:00 D: 999 | (00)00000000
pos( 260) T:43:10 D: 953 | (00)00000000
pos( 261) T:43:20 D: 956 | (00)00000000
pos( 262) T:43:30 D: 877 | (00)00000000
pos( 263) T:43:40 D: 800 | (00)00000000
pos( 264) T:43:50 D: 797 TEMP=39 Deco Stop at 6m Stop 13min | (04)00000100 (27)00100111 (00)00000000 (06)00000110 (0D)00001101
pos( 265) T:44:00 D: 768 | (00)00000000
pos( 266) T:44:10 D: 727 | (00)00000000
pos( 267) T:44:20 D: 693 | (00)00000000
pos( 268) T:44:30 D: 659 | (00)00000000
pos( 269) T:44:40 D: 653 | (00)00000000
pos( 270) T:44:50 D: 624 TEMP=38 Deco Stop at 6m Stop 13min | (04)00000100 (26)00100110 (00)00000000 (06)00000110 (0D)00001101
pos( 271) T:45:00 D: 615 | (00)00000000
pos( 272) T:45:10 D: 598 | (00)00000000
pos( 273) T:45:20 D: 587 | (00)00000000
pos( 274) T:45:30 D: 603 gas Change to 5 no alarm | (82)10000010 (20)00100000 (05)00000101
pos( 275) T:45:40 D: 586 | (00)00000000
pos( 276) T:45:50 D: 628 TEMP=38 Deco Stop at 6m Stop 12min | (04)00000100 (26)00100110 (00)00000000 (06)00000110 (0C)00001100
pos( 277) T:46:00 D: 629 | (00)00000000
pos( 278) T:46:10 D: 643 | (00)00000000
pos( 279) T:46:20 D: 640 | (00)00000000
pos( 280) T:46:30 D: 636 | (00)00000000
pos( 281) T:46:40 D: 636 | (00)00000000
pos( 282) T:46:50 D: 637 TEMP=37 Deco Stop at 6m Stop 11min | (04)00000100 (25)00100101 (00)00000000 (06)00000110 (0B)00001011
pos( 283) T:47:00 D: 670 | (00)00000000
pos( 284) T:47:10 D: 700 ppO high warning | (81)10000001 (05)00000101
pos( 285) T:47:20 D: 700 ppO high warning | (81)10000001 (05)00000101
pos( 286) T:47:30 D: 658 ppO high warning | (81)10000001 (05)00000101
pos( 287) T:47:40 D: 675 | (00)00000000
pos( 288) T:47:50 D: 679 ppO high warning TEMP=36 Deco Stop at 6m Stop 10min | (85)10000101 (05)00000101 (24)00100100 (00)00000000 (06)00000110 (0A)00001010
pos( 289) T:48:00 D: 653 ppO high warning | (81)10000001 (05)00000101
pos( 290) T:48:10 D: 618 | (00)00000000
pos( 291) T:48:20 D: 597 | (00)00000000
pos( 292) T:48:30 D: 611 | (00)00000000
pos( 293) T:48:40 D: 609 | (00)00000000
pos( 294) T:48:50 D: 603 TEMP=36 Deco Stop at 6m Stop 9min | (04)00000100 (24)00100100 (00)00000000 (06)00000110 (09)00001001
pos( 295) T:49:00 D: 622 | (00)00000000
pos( 296) T:49:10 D: 664 | (00)00000000
pos( 297) T:49:20 D: 668 | (00)00000000
pos( 298) T:49:30 D: 702 ppO high warning | (81)10000001 (05)00000101
pos( 299) T:49:40 D: 709 ppO high warning | (81)10000001 (05)00000101
pos( 300) T:49:50 D: 719 ppO high warning TEMP=36 Deco Stop at 6m Stop 8min | (85)10000101 (05)00000101 (24)00100100 (00)00000000 (06)00000110 (08)00001000
pos( 301) T:50:00 D: 719 ppO high warning | (81)10000001 (05)00000101
pos( 302) T:50:10 D: 727 ppO high warning | (81)10000001 (05)00000101
pos( 303) T:50:20 D: 741 ppO high warning | (81)10000001 (05)00000101
pos( 304) T:50:30 D: 747 ppO high warning | (81)10000001 (05)00000101
pos( 305) T:50:40 D: 703 ppO high warning | (81)10000001 (05)00000101
pos( 306) T:50:50 D: 635 ppO high warning TEMP=35 Deco Stop at 6m Stop 7min | (85)10000101 (05)00000101 (23)00100011 (00)00000000 (06)00000110 (07)00000111
pos( 307) T:51:00 D: 606 | (00)00000000
pos( 308) T:51:10 D: 612 | (00)00000000
pos( 309) T:51:20 D: 655 | (00)00000000
pos( 310) T:51:30 D: 679 ppO high warning | (81)10000001 (05)00000101
pos( 311) T:51:40 D: 654 ppO high warning | (81)10000001 (05)00000101
pos( 312) T:51:50 D: 650 TEMP=35 Deco Stop at 6m Stop 6min | (04)00000100 (23)00100011 (00)00000000 (06)00000110 (06)00000110
pos( 313) T:52:00 D: 623 | (00)00000000
pos( 314) T:52:10 D: 612 | (00)00000000
pos( 315) T:52:20 D: 587 | (00)00000000
pos( 316) T:52:30 D: 582 | (00)00000000
pos( 317) T:52:40 D: 620 | (00)00000000
pos( 318) T:52:50 D: 615 TEMP=36 Deco Stop at 6m Stop 5min | (04)00000100 (24)00100100 (00)00000000 (06)00000110 (05)00000101
pos( 319) T:53:00 D: 631 | (00)00000000
pos( 320) T:53:10 D: 613 | (00)00000000
pos( 321) T:53:20 D: 597 | (00)00000000
pos( 322) T:53:30 D: 615 | (00)00000000
pos( 323) T:53:40 D: 614 | (00)00000000
pos( 324) T:53:50 D: 649 TEMP=36 Deco Stop at 6m Stop 4min | (04)00000100 (24)00100100 (00)00000000 (06)00000110 (04)00000100
pos( 325) T:54:00 D: 654 | (00)00000000
pos( 326) T:54:10 D: 668 | (00)00000000
pos( 327) T:54:20 D: 704 ppO high warning | (81)10000001 (05)00000101
pos( 328) T:54:30 D: 646 ppO high warning | (81)10000001 (05)00000101
pos( 329) T:54:40 D: 641 | (00)00000000
pos( 330) T:54:50 D: 633 TEMP=35 Deco Stop at 6m Stop 3min | (04)00000100 (23)00100011 (00)00000000 (06)00000110 (03)00000011
pos( 331) T:55:00 D: 650 | (00)00000000
pos( 332) T:55:10 D: 664 | (00)00000000
pos( 333) T:55:20 D: 642 | (00)00000000
pos( 334) T:55:30 D: 626 | (00)00000000
pos( 335) T:55:40 D: 635 | (00)00000000
pos( 336) T:55:50 D: 659 TEMP=35 Deco Stop at 6m Stop 2min | (04)00000100 (23)00100011 (00)00000000 (06)00000110 (02)00000010
pos( 337) T:56:00 D: 674 ppO high warning | (81)10000001 (05)00000101
pos( 338) T:56:10 D: 681 ppO high warning | (81)10000001 (05)00000101
pos( 339) T:56:20 D: 682 ppO high warning | (81)10000001 (05)00000101
pos( 340) T:56:30 D: 718 ppO high warning | (81)10000001 (05)00000101
pos( 341) T:56:40 D: 740 ppO high warning | (81)10000001 (05)00000101
pos( 342) T:56:50 D: 676 ppO high warning TEMP=35 Deco Stop at 6m Stop 1min | (85)10000101 (05)00000101 (23)00100011 (00)00000000 (06)00000110 (01)00000001
pos( 343) T:57:00 D: 687 ppO high warning | (81)10000001 (05)00000101
pos( 344) T:57:10 D: 700 ppO high warning | (81)10000001 (05)00000101
pos( 345) T:57:20 D: 674 ppO high warning | (81)10000001 (05)00000101
pos( 346) T:57:30 D: 623 | (00)00000000
pos( 347) T:57:40 D: 642 | (00)00000000
pos( 348) T:57:50 D: 688 ppO high warning TEMP=35 Deco Stop at 0m Stop 240min | (85)10000101 (05)00000101 (23)00100011 (00)00000000 (00)00000000 (F0)11110000
pos( 349) T:58:00 D: 690 ppO high warning | (81)10000001 (05)00000101
pos( 350) T:58:10 D: 655 ppO high warning | (81)10000001 (05)00000101
pos( 351) T:58:20 D: 638 | (00)00000000
pos( 352) T:58:30 D: 633 | (00)00000000
pos( 353) T:58:40 D: 665 | (00)00000000
pos( 354) T:58:50 D: 692 ppO high warning TEMP=35 Deco Stop at 0m Stop 240min | (85)10000101 (05)00000101 (23)00100011 (00)00000000 (00)00000000 (F0)11110000
pos( 355) T:59:00 D: 706 ppO high warning | (81)10000001 (05)00000101
pos( 356) T:59:10 D: 706 ppO high warning | (81)10000001 (05)00000101
pos( 357) T:59:20 D: 701 ppO high warning | (81)10000001 (05)00000101
pos( 358) T:59:30 D: 660 ppO high warning | (81)10000001 (05)00000101
pos( 359) T:59:40 D: 681 ppO high warning | (81)10000001 (05)00000101
pos( 360) T:59:50 D: 718 ppO high warning TEMP=34 Deco Stop at 0m Stop 240min | (85)10000101 (05)00000101 (22)00100010 (00)00000000 (00)00000000 (F0)11110000
pos( 361) T:60:00 D: 709 ppO high warning | (81)10000001 (05)00000101
pos( 362) T:60:10 D: 690 ppO high warning | (81)10000001 (05)00000101
pos( 363) T:60:20 D: 656 ppO high warning | (81)10000001 (05)00000101
pos( 364) T:60:30 D: 649 | (00)00000000
pos( 365) T:60:40 D: 595 | (00)00000000
pos( 366) T:60:50 D: 573 TEMP=34 Deco Stop at 0m Stop 240min | (04)00000100 (22)00100010 (00)00000000 (00)00000000 (F0)11110000
pos( 367) T:61:00 D: 540 | (00)00000000
pos( 368) T:61:10 D: 440 | (00)00000000
pos( 369) T:61:20 D: 421 | (00)00000000
pos( 370) T:61:30 D: 420 | (00)00000000
pos( 371) T:61:40 D: 383 | (00)00000000
pos( 372) T:61:50 D: 341 TEMP=34 Deco Stop at 0m Stop 240min | (04)00000100 (22)00100010 (00)00000000 (00)00000000 (F0)11110000
pos( 373) T:62:00 D: 344 | (00)00000000
pos( 374) T:62:10 D: 316 | (00)00000000
pos( 375) T:62:20 D: 266 | (00)00000000
pos( 376) T:62:30 D: 210 | (00)00000000
pos( 377) T:62:40 D: 192 | (00)00000000
pos( 378) T:62:50 D: 201 TEMP=33 Deco Stop at 0m Stop 240min | (04)00000100 (21)00100001 (00)00000000 (00)00000000 (F0)11110000
pos( 379) T:63:00 D: 185 | (00)00000000
pos( 380) T:63:10 D: 174 | (00)00000000
pos( 381) T:63:20 D: 124 | (00)00000000
pos( 382) T:63:30 D: 99 | (00)00000000
pos( 383) T:63:40 D: 34 | (00)00000000
pos( 384) T:63:50 D: 42 TEMP=34 Deco Stop at 0m Stop 240min | (04)00000100 (22)00100010 (00)00000000 (00)00000000 (F0)11110000
pos( 385) T:64:00 D: 45 | (00)00000000
pos( 386) T:64:10 D: 30 | (00)00000000
pos( 387) T:64:20 D: 9 | (00)00000000
pos( 388) T:64:30 D: 26 | (00)00000000
pos( 389) T:64:40 D: 12 | (00)00000000
pos( 390) T:64:50 D: 23 TEMP=33 Deco Stop at 0m Stop 240min | (04)00000100 (21)00100001 (00)00000000 (00)00000000 (F0)11110000
pos( 391) T:65:00 D: 3 | (00)00000000
pos( 392) T:65:10 D: 16 | (00)00000000
pos( 393) T:65:20 D: 18 | (00)00000000
pos( 394) T:65:30 D: 8 | (00)00000000
pos( 395) T:65:40 D: 6 | (00)00000000
pos( 396) T:65:50 D: 2 TEMP=33 Deco Stop at 0m Stop 240min | (04)00000100 (21)00100001 (00)00000000 (00)00000000 (F0)11110000
pos( 397) T:66:00 D: 4 | (00)00000000
pos( 398) T:66:10 D: 4 | (00)00000000
pos( 399) T:66:20 D: 17 | (00)00000000
pos( 400) T:66:30 D: 15 | (00)00000000
pos( 401) T:66:40 D: 23 | (00)00000000
pos( 402) T:66:50 D: 52 TEMP=33 Deco Stop at 0m Stop 240min | (04)00000100 (21)00100001 (00)00000000 (00)00000000 (F0)11110000
pos( 403) T:67:00 D: 27 | (00)00000000
pos( 404) T:67:10 D: 4 | (00)00000000
pos( 405) T:67:20 D: 4 | (00)00000000
End of Dive
number of CF: 58 (3A)00111010
CF00 Act: 100 Def: 100
CF01 Act: 30 Def: 30
CF02 Act: 240 Def: 240
CF03 Act: 120 Def: 120
CF04 Act: 5 Def: 5
CF05 Act: 7 Def: 7
CF06 Act: 1160 Def: 1160
CF07 Act: 1080 Def: 1080
CF08 Act: 20 Def: 20
CF09 Act: 20 Def: 20
CF10 Act: 45 Def: 45
CF11 Act: 110 Def: 110
CF12 Act: 90 Def: 90
CF13 Act: 60 Def: 60
CF14 Act: 100 Def: 100
CF15 Act: 10 Def: 10
CF16 Act: 10 Def: 10
CF17 Act: 19 Def: 19
CF18 Act: 160 Def: 160
CF19 Act: 150 Def: 150
CF20 Act: 10 Def: 10
CF21 Act: 6 Def: 6
CF22 Act: 6 Def: 6
CF23 Act: 0 Def: 0
CF24 Act: 0 Def: 0
CF25 Act: 0 Def: 0
CF26 Act: 0 Def: 0
CF27 Act: 20 Def: 20
CF28 Act: 794 Def: 0
CF29 Act: 6 Def: 3
CF30 Act: 10 Def: 10
CF31 Act: 0 Def: 0
CF32 Act: 30 Def: 30
CF33 Act: 80 Def: 90
CF34 Act: 199 Def: 199
CF35 Act: 255 Def: 255
CF36 Act: 62 Def: 62
CF37 Act: 224 Def: 224
CF38 Act: 1 Def: 0
CF39 Act: 0 Def: 0
CF40 Act: 1 Def: 1
CF41 Act: 1 Def: 1
CF42 Act: 1 Def: 1
CF43 Act: 13000 Def: 13000
CF44 Act: 101 Def: 101
CF45 Act: 101 Def: 101
CF46 Act: 161 Def: 161
CF47 Act: 10 Def: 15
CF48 Act: 0 Def: 0
CF49 Act: 0 Def: 0
CF50 Act: 0 Def: 0
CF51 Act: 1 Def: 1
CF52 Act: 1 Def: 0
CF53 Act: 1 Def: 0
CF54 Act: 0 Def: 0
CF55 Act: 0 Def: 0
CF56 Act: 20 Def: 200
CF57 Act: 20 Def: 200
CF58 Act: 0 Def: 0
CF59 Act: 0 Def: 0
CF60 Act: 1 Def: 0
End of CF --------------------------------------
First:
I recieve 58.
Second:
What was different:
Gas 1: 12/55
Gas 2: 21/30
Gas 3: 31/35
Gas 4: 49/0 at 21m
Gas 5: 100/0 at 6m
Gas 6: 30/0
Third:
regards
Servus miteinander,
Erstens:
Der leichte
Zweitens:
Gas 1: 12/55
Gas 2: 21/30
Gas 3: 31/35
Gas 4: 49/0 bei 21m
Gas 5: 100/0 bei 6m
Gas 6: 30/0
Drittens:
Grüße
DiveNumber: 794
Gas 1: 12/55
Gas 2: 21/30
Gas 3: 31/35
Gas 4: 49/0
Gas 5: 100/0
Gas 6: 30/0
Maximum CNS (%): 42
GFLo: 30
GFHi: 80
Salinity: 1
Profile data
ProfileOffset: 258
End of Dive
CF04 Act: 5 Def: 5
CF05 Act: 7 Def: 7
CF21 Act: 6 Def: 6
CF22 Act: 6 Def: 6
CF23 Act: 0 Def: 0
CF24 Act: 0 Def: 0
CF25 Act: 0 Def: 0
CF26 Act: 0 Def: 0
CF29 Act: 6 Def: 3
CF31 Act: 0 Def: 0
CF38 Act: 1 Def: 0
CF39 Act: 0 Def: 0
CF40 Act: 1 Def: 1
CF41 Act: 1 Def: 1
CF42 Act: 1 Def: 1
CF48 Act: 0 Def: 0
CF49 Act: 0 Def: 0
CF50 Act: 0 Def: 0
CF51 Act: 1 Def: 1
CF52 Act: 1 Def: 0
CF53 Act: 1 Def: 0
CF54 Act: 0 Def: 0
CF55 Act: 0 Def: 0
CF58 Act: 0 Def: 0
CF59 Act: 0 Def: 0
CF60 Act: 1 Def: 0
