Jdivelog on mac osx 10.7.3
maxtosca69
I'm not able to setup/fix "driver" in dive computer settings and "com port".
I'm sure that com port works correctly when I use OSTC planner or Macdive.
Somebody can help me?
OSTC 1426 v.2.01
OSTC 1426 v.2.01
maxtosca69
Re: Jdivelog on mac osx 10.7.3
I can't setup any settings both in Jdivelog 2.15 and previous versions
OSTC 1426 v.2.01
OSTC 1426 v.2.01
Can you choose OSTC in the driver pull down menu?
[img]http://www.heinrichsweikamp.com/file.ph ... lungen.jpg[/img]
If you can't choose these settings in jdivelog then I would suggest you reinstall jdivelog. I doubt very much its a com port problem.
maxtosca69
I've installed jdivelog several time but every time I can't choose OSTC in the driver pull down menu.
Help me please!!!
Will be possible in future to upload firmware with a new version of OSTC planner for Mac users as is the case with bootdownloader for win? I hope so
Help me please!!!
Does your driver (treiber) pull down menu look like this?
[img]http://www.heinrichsweikamp.com/file.ph ... ivelog.jpg[/img]
Do you have the choice of dive computers, you see in the picture, in your pull down menu?
maxtosca69
Ya but it is impossible to choose anything
maxtosca69
I repeat that both macdive and ostc planner are able to recognize my MK" thus there exists com port
You have two options.
1. See whether you can get help in the jDiveLog forum.
2. Find a friend with the PC so you can install the firmware update on a PC.
Ohh and finally, have you tried on another Mac?
Or use virtualboxon mac
I don't understand why it doesn't work with your mac
I do see the point though that there should be a Bootloader for Mac. Unless the SW for the frog could also be used for the 2N. I am sure the SW for the frog will have a Mac version (I hope)
Also I would think it would be neat if JD could include a FW upgrade in OSTC Planner.
herr meier
hallo!
gibt es neuere oder andere treiber für den mac mit 10.7 ???
bei mir ist plötzlich keiner mehr da auch nicht nach erneuten installationsversuchen.
bin ein wenig ratlos
um das wort angefressen nicht benutzen zu müssen
herzliche grüße
herzliche grüße
herr meier Wrote:
> hallo!
> mit 10.7 ???
Hast den OSTC per USB am Mac angeschlossen? Der Treiber wird nur dann auswählbar...
> hallo!
> mit 10.7 ???
herr meier
wie sonst ???
über nen bindfaden ???
er wird auf jeden fall geladen (ladelämpchen blinkt) aber das soll ja nichts bedeuten.
im system-profiler wird er auch angezeigt.
am ppc mit 10.5.8 wird er noch erkannt und es wird auf wunsch auch der versuch unternommen daten vom ostc zu holen, nur hängt sich dann jdivelog auf.
hg
hg
herr meier
so
nach etlichen versuchen ist es mir gelungen.
der treiber ist wieder da aber "Der Com Port ist bereits besetzt" ist der dauerbrenner auf allen kanälen
egal welche Protokoll Version ich auch nehme,
herr meier Wrote:
> wie sonst ???
Nein, hät ja sein können dass du den Compi nicht am Mac hängen gehabt hättest, dann ist auch der Treiber nicht auswählbar...
> wie sonst ???
Und was hängt sonst noch alles per USB dran? Ich hatte z.B. mal meine GoPRO Kamera angeschlossen, da wurde der OSTC auch nicht erkannt... Also mal alles ausstöpseln und nochmals probieren.
herr meier
hat jemand ne brechstange oder nen hammer ???
mir als altem apfelnutzer ist ja schon einiges untergekommen aber so etwas hab ich noch nicht erlebt.
ich werde jetzt spasseshalber mal 10.6 drauf zwirbeln mal sehn ob mir das was bringt
hat damit jemand erfahrungen sammeln können ???
eines kommt mir überhaupt nicht in die tüte b.z.w. auf den rechner
wind dos
hg
wind dos
hg
Did you try to run JDiveLog as root?
JDiveLog as root:
To run as root:
1. Open terminal
2. enter: sudo su root
3. enter: /Applications/JDiveLog.app/Contents/MacOS/JavaApplicationStub
If this works, your problem is that 'you' are not in the _uupc group.
Where 'you' is your account on your Mac.
You get to know your account name if you execute:
whoami
in a terminal
To make an new group on your Mac and add your account to that group, execute the following commands:
first switch to 'root' :
sudo su root
Create a group with groupname _uupc:
sh-3.2# sudo dscl . -create /groups/_uupc
Give that group _uupc a groupid 66
sh-3.2# sudo dscl . -append /groups/_uupc gid 66
Add a user bruno to group _uupc
sh-3.2# dscl . append /Groups/_uupc GroupMembership bruno
Check group membership of user bruno:
Bruno-Van-Bogaerts-MacBook:~ bruno$ id
uid=501(bruno) gid=20(staff) groups=20(staff),401(com.apple.access_screensharing),204(_developer),100(_lpoperator),98(_lpadmin),81(_appserveradm),80(admin),79(_appserverusr),61(localaccounts),12(everyone),66(_uucp),402(com.apple.sharepoint.group.1)
[note from the author: I added the bold type]
JDiveLog as root:
To run as root:
1. Open terminal
whoami
in a terminal
sudo su root
herr meier
hallo
ich wollte mich wenigstens noch bedanken denn ich hab es in den griff bekommen, herzlichen dank!!!
woran hat's gelegen? vielleicht hat mal jemand anders die gleichen Probleme...
Marko1709
Servus,
scheint ich habe ein ähnliches Problem. Was hat letztendlich zur Lösung geführt?
Gruss
Besten Dank
Marko
Gruss
Besten Dank
Marko
darf ich dich nach deinem Lösungsweg fragen? Ich kämpfe erfolglos mit dem selben Problem ! Wen ich jedoch die Linux Version installiere, dann funktioniert es !
Ich benutze die aktuelle OSX 10.8.2
Besten Dank im voraus
Chris
Chris
Was genau ist euer Problem?
