OSTC 2n
Phil M
OSTC 2n
Post by Phil M »
treid to use my OSTC today for the firts time - i have a blank screen and no display - can anyone help?
Can i try and re-boot it if so how?
thanks
Re: OSTC 2n
Have you ever managed to switch it on?
What happens when you plug it in at the PC with the USB cable? There should be a little red light flashing app. every second in the center at the bottom of the screen while the 2N is charging.
[img]http://www.heinrichsweikamp.com/file.ph ... all%29.JPG[/img]
If you need to reboot the 2N you plug it in at the PC and while its plugged in touch it with a magnet on the back near the little screw in the center.
