Maybe I have done something wrong when setting my 2n but I've put my last stop at 6 meter because that is the optimal depth for ccr (Megalodon). But when I bailout I would prefer to have my last stop at 3 meter cause that would save me a lot of gas.
Is there a CF setting that would make this possible or should I simply set my last stop at 3 meter and then live with the fact that the TTS is never correct while on CC?
Curious on how you deal with this or if this is an option that could still be embedded?
Greetings,Olaf
3m last stop on ocbailout while 6 meter on cc
Solodiver
Re: 3m last stop on ocbailout while 6 meter on cc
Olaf, why should a last stop at 6m be optimal for CCR?
Olaf70
The last place where I can run the CCR at ppO2 1.3 and higher.
If I go above the 5 meter then I need to run low setpoint.
Solodiver
OK, but what is wrong with lower setpoints? The decompression quality should be (much) better on 3m than staying on 6m!?
