After a brief look at 1.26 it looks promising.
Questions regarding:
NEW: Added Menu entry "Calibrate x %O2" in "O2 Sensor Menu"
NEW: Added CF37: HUD style (OSTC, DS1, RGB, Smithers) (OEM O2 sensor electronic)
1. Yes I find the Calibrate x %O2, where do I set what PO2 to calibrate to?
2. The setup #37 states HUD style [0-3] but there is three possible values, which is 0,1,2? I guess 3 is not valid?
1.26 questions
Re: 1.26 questions
That's your Diluent or "Start Gas" in Menu -> Gas Setup
> 3 is not valid?
0=OSTC
1=DS1
2=RGB
3=Smithers
The new HUD styles require the ppO2 monitor board with firmware 1.1 or later.
> 3 is not valid?
0=OSTC
1=DS1
2=RGB
3=Smithers
