New firmware 2.28beta
Was gibt's neues?
BUGFIX: Blink better gas in bailout case (if CF42=1)
- Das wird jetzt auch im Bailout-Fall angezeigt.
CHANGE: Surface screen layout change
- Der Dekomode steht nun oben links, die Gasanzeige ist neu
BUGFIX: Use CF01 for end-of-dive detection
CHANGE: CF01 default to 50cm
- Beim Auftauchen endet der TG in 50cm Tiefe
http://www.heinrichsweikamp.com/#/de/ostc_2n/firmware/
What is new?
- The gas change is indicated in Bailout now, too.
- The decomode is displayed top-left and the gas display is new
- When reaching the surface the dive is ended in 50cm depth
http://www.heinrichsweikamp.com/#/en/ostc_2n/firmware/
Was gibt's neues?
What is new?
Re: New firmware 2.28beta
Did the update using OSTC-Planner, everything worked perfect (*). Will go diving tomorrow... (:D
(*) except Date & Time are reseted to zero - but for this i have JDiveLog to synchronize again
Ok...
> and the gas
> display is new
Honestly i don't understand what this bottle symbol is for... Especially when "filled" with Trimix, it looks like the bottle is to small for the word "Trimix"...
And i'm not sure about the shortcuts you're using:
Tx for Trimix is somehow common, but Nx for Nitrox?
I'm used to EAN and TMX, and because we have 3 letters then, AIR would fit into a logical order...
In my eyes it doesn't make sense to have both, the bottle-symbol and the text-letters... Especially i don't like the brown color when in Trimix-mode
Ok...
> and the gas
> display is new
Just set CF41 to off and the symbol is gone. It's useful especially for Multi-gas dives...
Good work!
Regarding the safety-stop feature (CF65), I'm glad you added it.
I almost always dive with my set of doubles even though the dive itself don't require them, it gives muscle memory and repetition.
For the same reason it's nice to have the possibility to have safety-stop reminder turned on while diving No-deco dives while on holiday or other friends.
One wish though; Please set the default values to 6-3m. I thinkt that's the range most other brands use.
Thanks,
Petter
Thanks,
Petter
/Petter
Trimix, Full Cave, Instructor
> OSTC 2N #4292 - 3.00
Arctic Diver
Newbie-Frage:
Gehen bei einem Update meine persönlichen Einstellungen bei den CF's verloren?
Arctic Diver Wrote:
> Newbie-Frage:
Bei Betas i.d.R. nicht, bei Stables i.d.R. schon.
> Newbie-Frage:
Gorgeous! And can we have CF's for setting the bottle colors, please?
>:D< *SCNR*
Just kidding. You did a good job once again! So thank you for your efforts
>:D< *SCNR*
Der best mix. blingt nicht ob wohl ich CF42=on habe.
Muss man noch was anderes einstehlen ?
Meine Bailout haben eine max. tieffe so das sie auch actif sind.
MFG
MFG
Hi Mike,
der Hinweis auf den verpassten Gaswechsel kommt innerhalb eines Fenster von 3m oberhalb der konfigurierten Wechseltiefe. Das geht in der 2.28 wie es soll.
Ok, danke fûr die Info, werde es wieder probieren.
MFG
Mike
MFG
Mike
> using:
> Nitrox?
NX is quite common for Nitrox.
> using:
> Nitrox?
Oliver Ritzmann
Hallo!
Ich bin ebenfalls für die Änderung des Safety Stopps auf 6-3m, dann macht CF65 absolut Sinn.
Bei den Fun-Dives hier in Mexikodie letzten Tage nervt es schon etwas, dass die Zeit anhält, sowie man 5m wieder erreicht hat. Man hängt immer zwischen 4,70 und 4,90m, damit es passt. Bei schöner Welle nicht so einfach.
CU Oliver
CU Oliver
Used 2.2.8 today for two shallow dives. The safety stop timer works from 5 m but once you drop below 5 m it disappears. Would be better if it stays visible till a bit deeper. Still think it should start recording at 6 m. Will test deeper tomorrow, but still not a deco dive.
Michael
Sydney
Australia
OSTC 2 11528
Sydney
Australia
OSTC 2 11528
You won't degas much at 6m (Assuming a single-gas, no-deco dive -> low tissue load). Difference between ambient pressure and the overpressure in your tissues is quite low.
I think 3min between 3 and 5m is common sense in diving education.
I thing is better if safety-stop is between 3-6m.
If buddy use Suunto computer safety-stop start 6m. Then i have same deep as my buddy.
If buddy use other computer (5m) i can go 5m whitout any problems.
Not any harm (problems) if safety-stop is between 3-6m.
My opinion.
KP
My opinion.
KP
> diving education.
> regards,
> Matthias
Depends on how rough the sea is. It can get a bit exciting where we dive here to be spending much time at 3m.
Some agencies specifically teach safety stop at 6m. I think BSAC (British) does (again related to typical sea conditions in Britain) and given how many members it has it might be worth checking that out before the feature is fixed. A lot of potential customers there.
> diving education.
> regards,
> Matthias
Stephen McMullan
Dublin, Ireland
OSTC MK2 #850
www.technicaldiving.ie
Dublin, Ireland
OSTC MK2 #850
I have a suggestion for you.
Disable the Safety Stop function and start your safety stop at whatever depth you like.
All major agencies require 5 meters, which is not possible the way it is implemented right now in the OSTC, simply because it stops counting at a few centimeters below 5 meters.
The floor of the safety stop windows should be 6m simply to allow the stop to be performed at (meaning close to) 5m. Making the acceptable floor 5,50m would be good enough, but not 5m. Otherwise the feature might as well be removed again because it is useless for performing 5m safety stops.
Oliver
OSTC Mk2 1830
OSTC Mk2 1830
So remove this function and use the stopwatch with the depth you want
Time and depth of the safety stop are very easy to adjust in the source code....
Want different depths or time? Compile your own.
Don't want it all toghether? Switch it off.
PS: Next stable version I will adjust the depth for the safety stop for 6-3 meters, compile and post the firmware in English. Other languages by request. Just because I do like the safety stop feature B)-
OSTC 2N #4807
> feature B)-
(tu)
> feature B)-
(tu)
For testing: v2.28 beta with adjusted safetystop 6 to 3 meters, 3 minutes.
OSTC 2N #4807
Oliver Ritzmann
Hello!
@DiverM
Could you be so kind and compile the 2.28beta with a safety stop between 3 and 6m in the german language? At the moment I'm in Mexico and the stop not under 5m is not practicable in this rough sea.
Thanks in advance.
CU Oliver
@DiverM
Thanks in advance.
CU Oliver
