Highlight the "better gas" in the gaslist
Hi all,
I couldn't find the original post (Probably buried between safety stops) but I have now added some lines of code highlighting the "better gas" in the gas list. I think this is a useful extension finding the configured gas during a gas change.
[img]file.php?2,file=290,filename=OSTC.png[/img]
Re: Highlight the "better gas" in the gaslist
Will the gaslist appear automatically when a better gas is available and can i press right button to activate the recommendet gas?
Is this available in the new 2.50 version ?
Yorn
Yorn
Yorn
OSTC MK2
OSTC MK2
No, only in the current development branch (aka future 2.51 beta).
OSTC 2N #2755
read.php?2,9338,9342#msg-9342
Again, thanks for your great support Matthias!
It's fun to read about the updates you do to the OSTC!
/Petter
Trimix, Full Cave, Instructor
> OSTC 2N #4292 - 3.00
I've loaded the new stable version 2.50. Really good work guys. I think the blink better gas is a very good feature.
Using the simulator I noticed that the blinking starts 1m shallower than the MOD of the best gas. Also the blinking turns off 4m shallower than the MOD. I presume this is intended?
Stephen McMullan
Dublin, Ireland
OSTC MK2 #850
www.technicaldiving.ie
Dublin, Ireland
OSTC MK2 #850
DTR.Diver66
would it be possible that the flashing of better gas begins on the set MOD and not just a meter above?
I think this is intended and indicates that the OSTC will "give up" on the suggested gas and recompute deco assuming that you will not switch ...
Olivier.
OSTC 2N #3059
OSTC 2N #3059
Jean-François
Sorry to bother, but this change isn't in v2.50 is it ? I've tried the simulator but the better gas wasn't highlighted in yellow.
OSTC Mk2N 2287
It will be in the next beta...
Jean-François
> Regards,
> Matthias
Lovely. Thanks a lot
> Regards,
> Matthias
OSTC Mk2N 2287
