GAS SETUP
marcasnow
GAS SETUP
Post by marcasnow »
Hello
I have just purchase OSTC. I found an anomaly with respect to the instruction book...
when I set a mix in the GAS SETUP and I want to set the depth of use, the instruction manual says to select MORE e the instruction manual says to select and set with MORE DEPTH + or - the depth of use, and the corresponding PPO2 is marked on the second line BACK.
In my OSTC there isn't BACK and consequently there isn't PPO2.
I have the version 2,50 but my friend has the previous version but he also has the same problem.
You know give me an explanation?
Thank's
Andrea
Bardass
Re: GAS SETUP
Post by Bardass »
do you have a picture ?
when you click on More ... on the screen "GazList", you should have this screen (see attachment)
Bardass
marcasnow
Re: GAS SETUP
Post by marcasnow »
> attachment)
Hi Bardass
Yes, I have this screen but but in the instructions it says that there must be the BACK so I can set the maximum depth of use and PPO2 at that depth.
is it normal?
in attached the photo of the instruction booklet. I do not have the voice
regards
Andrea
Bardass
Re: GAS SETUP
Post by Bardass »
do not read instruction booklet !
it has not been updated for a long time.
use Depth +/- to change MOD on the screen and exit to go back
Attention : you don't need to change depth for the first gaz
first gaz need to be set at 0m
Bardass
marcasnow
Re: GAS SETUP
Post by marcasnow »
thanks for your answer!
I thought that I had to turn some custom function but I could not find it.
to have this function would have been nteresting because so we have the END of the first screen set for the PPO2 that interests us
Andrea
