Changelog for this beta:
CHANGE: GF_hi default now 85% (CF33)
NEW: aGF: Alternative GF (CF67 and CF68). Can be switched underwater if CF69=1
NEW: CF67: aGF_lo [%]
NEW: CF68: aGF_hi [%]
NEW: CF69: Allow GF change (underwater)
CHANGE: Deco model default now is L16-GF OC (OC, GF-Deco) WARNING: This update will reset Custom Functions!
Custom Function Documentation in english and german adopted.
Servus miteinander,
Beschreibung der Custom Fungtions in englisch und deutsch ist ergänzt.
Grüße/regards
if you go in the Reset Menu and do a "Reset CF, Gas & Deco" the Decotype is set to L16-FG OC.
rob
back from a nice 50m dive. The new feature aGF is working properly. Even the gray-out TTS and ceiling after gas change (until new plan is ready) is a good solution and also works ok
ZH-L16 OC (thats the old default)
Gauge
ZH-L16 CC
Apnoe
ZH-L16-GF OC (the new default)
ZH-L16-GF CC
pscr-GF
Its just a change when you reset the Computer.
This time all the CF settings were reseted? I did not expect this - so i did not take any notes before the update... So it would be nice - next time - if you can give an information like "this beta resets all settings" or something like that... Otherwise it costs me again "hours" to find my favorite battery color >:D<
swissdiving Wrote:
> GF-Deco is. Is GF-Deco a new Decotype?
The default decotype was "standard" Bühlmann from the very first OSTC firmware.
This has now been changed. Even non-technical divers (We assume 50% of the OSTC users are rec-divers doing decompression dives from time to time) will benefit from this deco approach:
21min @ 42m on Air will result in:
Standard Bühlmann (ZH-L16 OC):
6m - 6'
3m - 15'
TTS: 26'
Thanks Matthias,
I think its a sensible change as it adds some conservatism. I've been diving on GF for quite a while now. I also support the change to 85.
DTR.Diver66 Wrote:
> Hello Matthias,
Can you post the dive downloaded with OSTCtools, please?
DTR.Diver66 Wrote:
> I will do that in a few days because I'm not at
> home right now. Is there a bug in the FW or what
> is the reason?
