DiveMate +OSTC 2N(clone)+Android Tab
Dikon
Post by Dikon »
Hi!
I have clone of OSTC 2N computer (seawooch). Trying to download logs on my Samsung Galaxy Tab 10.1 (android 4.0.4). But unsuccessfully :(.
Yesterday, I download all my logs from Galileo Sol via IR adapter.
Divemate say : "Please connect the USB host cable and USB interfase to this device. Then switch the dive computer to PC mode."
When I press "Start transfer", it say: Error.... set the dive computer in PC mode...
Where is PC mode?
[IMG]http://s019.radikal.ru/i637/1306/c4/8d4939160177.jpg[/IMG]
[IMG]http://s017.radikal.ru/i413/1306/a1/61f6685acb76.jpg[/IMG]
Thank you.
Re: DiveMate +OSTC 2N(clone)+Android Tab
Ask the manufacturer - we don't give support for OSTC "clones" here.
Are you sure that Android can handle this kind of USB-Connections? I don't believe so, so i'm surprised that you can use an IRda-Device to transfer data...
Dikon
Post by Dikon »
> OSTC "clones" here.
Thank you, Matthias.
But, I hope that the same software have the same problems.
What they mean when ask to swith computer to PC mode?
Thank you, again.
I understand you.
> transfer data...
Yes. I'm absolutely sure.B)-
On screenshots you can see, parts of my dives that I download 2 days ago via IRDA.
http://www.youtube.com/watch?v=ici7hcAYLEA
Many years I use my Palm Treo to download logs from my divecomputers, but now I use Android smartphones with usb host inside, like Galaxy Tab and Galaxy Note-1
Dmitry.
> problems.
This isn't a software problem.
Yes but an IRDA-Device is a typical Input-Device,
with a very low power consumption... But a Device
like an OSTC will be charged over USB. So my opinion
is that the Android device will block the USB connection
unless it is plugged to a PC where the Tablet can get
power over USB... This is how i understand "PC mode".
You should buy a Windows 8 tablet (not RT!), this will
work. Have a look here: read.php?2,11262
Dikon
Post by Dikon »
> opinion
> connection
> get
> mode".
> will
> read.php?2,11262
Thank you for you attention!
I think you are right!
I want to try the Y cable with external power.
I have only one question: If there anybody download logs from original ostc 2n to Divemate (Android) via usb wire?
It's my goal, to use android smartphone to download logs,because all my Win smartphones was a "Holiday, which always with you"
Problem in that: I don't have enough time for holidays (:D
Maybe you just need to buy / install the USB-Pack from DiveMate. Have a look here:
http://www.confitek.de/en/products/DiveMate/prices.php
Anyway, is someone else using OTSC with android devices with success?
Dikon
Post by Dikon »
> .php
I have all three packages from DiveMate, and I have firmware 2.70 from OTSC
Tomorrow, I want to try additional 5 v the adapter.
BANDiver
Post by BANDiver »
> OSTC "clones" here.
Most of all problem that DiveMate don't support our "clone" - we are using different USB/UART IC:
Original OSTC: FT232R USB Interface Chip
Seawooch "clone": CP2102 (Silicon Labs.)
As I think you could ask developer of the DiveMate to add driver for this IC into s/w too.
> OSTC "clones" here.
Discuss this somewhere else, please.
