jdive log with ostc 2c
hello ,
I installed jdivelog on my pc w.7, I have a octc 2c.
the pc recognized the port, but after if I want to transfer, the error message is " no driver".
On the menu, the port is ok, the firmware is on Auto.:S
Can I have your help please ?
thanks
thanks
Re: jdive log with ostc 2c
Try to set the firmware option to the latest possible version... Not on auto!
The latest is not on the menu !
thanks Bardass I'll try this evening with it
"1.91 - X" means X is the latest, and all others from 1.91 on...
A friend of mine has the same problem after flashing the latest firmware for color of activ gaz, and for simulation (do not consider the other gaz activ in simulation)
I followed your suggestions for protocol:)-D.
JLDIVE upload only the first dive and not the others following.
do you have an idea of how to extract all ?
thanks
thanks
i have the them problem with upload the dive,
the 4 last dive don't upload.
If you have some idea for this problem ???
I have this problem with OSTC 2C !
With my OSTC 2N i have no problem !
Jdivelog 2.18 + RXTX 2.1 + Protocol OSTC 1.91 - X
Firmware V2.80
Christophe
Firmware V2.80
Christophe
JDivelog not work with OSTC!
Use Subsurface.
Use Subsurface.
