it´s the second time I have updated my OSTC, and I´m having a problem, to wich I haven´t found a solution on the forum I hope you can help me solving it!!
To star up I have to say that there is a small failure (bug) when using the Spanish language option, when entering CCR Setup menu, the next screen apairs totaly blanck with the exception of the exit option, in any case if entered the first possition, I can still edit the DIL gases, and on the second possition I can edit the setpoints; it´s just that the menu does not have any titles on them.... just for you to know.
Apart from this issue, I will try to explain my problem...
Where there used to be the selected gas (trimix in this case), on the right botton part some funny leters appear, and keep changing in the same sequence... I have no idea of wich gas is selected and running as CCR active gas. All this while on surface mode, havent had the change to get it on the water...
Since this problem has appeared with the spanish language option, I have reinstalled the English version, and the same thing has happend.
Any ideas on how to solve it?
Thanx in advance
