I dive a Classic kiss, the way the wiring and kidney are made the displays have to go on your left arm.
I would like to try an have my OSTC integrated with my Kiss cells.
Is there any way a software update could include the option to flip the screen 180 degrees, thereby having the fischer connector pointing up my arm and not toward my hand as it is at the moment?
Screen Flipping
Re: Screen Flipping
Right now there's no option to flip the screen, sorry.
Fischer also provides angled connectors, maybe this is a fast alternative for you?
Re: Screen Flipping
Hi
Even fitting an angled fischer connector the cable is still going to be a potential snagging hazard, plus thats another failure point introduced.
Vincent Kessler
Re: Screen Flipping
Hi Gareth,
i've made a modified firmware 1.30 for you. The screen as well as the buttons are flipped. You can download it here:
http://quantec-gw0.dyndns.org/gallery2/ ... emId=21963
Vincent
Vincent
Vincent Kessler
Re: Screen Flipping
Please note, that holding a button doesn't work. I hope, that i've got the time to fix this tonight.
Vincent
Vincent
Re: Screen Flipping
Hi Vincent,
Thanks for the update on screen flipping, one I get back home again I will update my OSTC.
regards
Gareth
regards
Gareth
Vincent Kessler
Re: Screen Flipping
Hi again,
everything should work now with the flipped version.
Ive also added a unified diff as well as a copy of the license.
Get it here:
http://quantec-gw0.dyndns.org/gallery2/ ... emId=24370
Vincent
Get it here:
Vincent
Re: Screen Flipping
This code has now been added to the next beta (CF39=1 will flip the screen). To avoid confusion with the inlay ( "ENTER" & "SET/MENU" ) we did not exchanged the switches.
Thanks for your help, Vincent!
