Have a look here:
file.php?2,file=448,filename=Custom_Functions_V2_70.pdf
Your first adress for documentation is www.heinrichsweikamp.com
OSTC2: New 2.90 firmware
Re: OSTC2: New 2.90 firmware
dandipdive Wrote:
> CF57!
> CF56!
> what does this means?
CF56 and CF57 are not within their recommended boundaries.
Reset them in the CFII menu.
> CF57!
> CF56!
Arctic Diver
Just did the update from V2.50 to 2.90.
Installation went well. No Probs. 55 sec - done.
Then I tried the new firmware in German (my native language) - but I didn't like it and changed back to english.
So, let's rock'n'roll with V2.90
OSTC 4914 V2.50
Frappawotsit
My Update to V2.90 via a MAC and using JDivelog to complete the upgrade went smoothly..... new firmware ready to dive!
After 3x Failed OSTC3's... I finally settled for an OSTC2c (#7138).... So far, so good!!!!
Tecchiegirl
Upgrade went smoothly. Unfortunately it wiped out my logbook! Any way I can retrieve this please?
I can't see why an upgrade should influence the logbook data. From which version did you upgrade to the 2.9 and which update tool did you use?
moki82
there is Italian translation for firmware 2.90?
nodekh
Hi.
After upgrading from 2.21 to 2.90 every CF higher than 73 is set to 255 and the unit indicates that default is 0. Should I change every to 0?
Another thing is that I can not switch CF69 to off.
OSTC 2N 4689
Continue here: read.php?2,14038
